Enlarging and Reducing Prints
0UKW-091
You can adjust the image size of JPEG and TIFF files to match the paper size when printing.
As an example, the procedure for printing files that are stored in memory media is explained in this section.
You can use this mode only when printing JPEG or TIFF files.
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the location where the file you want to print is stored.
Select the desired file → press [Print].
4.
Select the paper source → press [OK].
5.
Press [Options] → [Enlarge/Reduce] → [Close].
To change the paper source, see
"Paper Selection."
