[Long Edge]:
Uses the long edge of the paper as the binding location for the back and front sides.
[Short Edge]:
Uses the short edge of the paper as the binding location for the back and front sides.
You may not be able to print, depending on the paper type.
Paper used to make two-sided prints must conform to the following specifications:
Paper size: LTR, LGL, STMT, EXEC (envelopes cannot be used for two-sided printing)
Paper weight: 16 lb bond to 60 lb cover (60 to 163 g/m2)
If there are an odd number of pages in the file, the back side of the last print is left blank. (The machine's counter does not count the blank page as a print.)
If you select a PDF file together with the Auto Select Paper mode, and the pages that you want to print are of different sizes, the pages are printed as one-sided prints on paper of their respective sizes. If you want such pages to be printed as two-sided documents, select the correct paper sizes in advance.
