e-ManualTopSite mapHelp
Top » Access Stored Files » Arranging Files and Folders Stored in Memory Media » Checking File Information/Deleting Files
0UKW-089
You can check the detailed information for files on the memory media (file name, location, date modified etc.), and delete files.
Checking the Detailed Information for a File
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the directory where the file you want to check is stored.
Select the desired file → press [Edit File].
4.
Press [Details] → [OK].
If you want to change the file name, press [Change File Name].
For information on the icons displayed on the Details screen, see "Types of Network/Memory Media Icons."
Deleting a File
Select the desired memory media → select the directory where the file you want to delete is stored.
4.
Press [Delete].
5.
Press [Yes].
Changing a File Name (Change File Name)
Select the desired memory media → select the directory where the file you want to change the file name is stored.
4.
Press [Change File Name].
If you select multiple files and press [Change File Name], the selected (highlighted) file becomes the file whose title is changed.
5.
Enter a file name → press [OK].
