Checking File Information/Deleting Files
0UKW-084
You can check the detailed information for files (folder name, location, date modified etc.), and delete files stored on the network.
Checking the Detailed Information for a File
Press [Access Stored Files] → [Network].
Select the desired storage location → select the location where the file you want to check is stored.
Select the desired file → press [Edit File].
4.
Press [Details] → [OK].
If you want to change the file name, press [Change File Name].
For information on the icons displayed on the Details screen, see
"Types of Network/Memory Media Icons."
Select the desired storage location → select the directory where the file you want to delete is stored.
4.
Press [Delete].
5.
Press [Yes].
Change a File Name (Change File Name)
Select the desired storage location → select the directory where the file you want to change the file name is stored.
4.
Press [Change File Name].
If you select multiple files and press [Change File Name], the selected (highlighted) file becomes the file whose title is changed.
5.
Enter a file name → press [OK].
