Before using this function, it is useful to read the following topics:
Main Power and Energy Saver key (See "Main Power and Energy Saver Key.")
Entering Characters from the Touch Panel Display (See "Entering Characters from the Touch Panel Display.")
Routine Maintenance (See "Maintenance.")
If you are using a login service, log in and out of the service before and after operating the machine.
If you are using Department ID Management, see "Entering the Department ID and PIN."
If you are performing user authentication using the SSO-H login service, see "Login Service."
