0UKW-08Y
You can add comments when printing PDF files.
As an example, the procedure for printing files that are stored in memory media is explained in this section.
You can use this mode only when printing PDF files.
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the location where the file you want to print is stored.
Select the desired file → press [Print].
4.
Press [Options] → [Print Comments].
To change the paper source, see
"Paper Selection."
5.
Press [Auto] → [OK] → [Close].
Comments specified within the PDF file are printed together with the file.
If you do not want to print the comments, press [Do Not Print].
