Recalling/Deleting Favorite Settings
0UKW-08F
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the location where the file you want to print is stored.
Select the desired file → press [Print].
If you select a PDF or XPS file, proceed to step 5.
4.
Select the paper size → press [OK].
5.
Press [Favorite Settings].
6.
Select the desired button.
Recalling Favorite Settings:
Press [OK].
Press [Yes].
You can make changes to the recalled settings.
Deleting Favorite Settings:
Press [Delete].
Press [Yes].
The name for the button is not deleted. To change the name of a button, press [Rename].
Press [Cancel].
