e-ManualTopSite mapHelp
Top » Access Stored Files » Favorite Settings » Storing Favorite Settings
0UKW-08E
Press [Access Stored Files] → [Memory Media].
Select the desired memory media → select the location where the file you want to print is stored.
Select the desired file → press [Print].
If you select a PDF or XPS file, proceed to step 5.
4.
Select the paper size → press [OK].
5.
Specify the print settings → press [Favorite Settings].
6.
Select the button to register to → press [Register].
To rename a button, select the button → press [Rename] → enter the name.
7.
Press [Yes].
8.
Press [Cancel].
