Category Top
Overview of This Function
Advanced Box/Network Settings
Mail Box
Advanced Box
Network
Memory Media
Flow of Operations for Accessing Stored Files
Printing Files Stored in a Mail Box
Printing Files Stored in the Advanced Box
Printing Files Stored on the Network
Printing Files Stored in Memory Media
Canceling a Job While Printing
Reserving Jobs
Arranging Files Stored in a Mail Box
Checking File Information
Previewing a File
Operations for Files Stored in a Mail Box
Printing Lists
Arranging Files and Folders Stored in the Advanced Box
Checking Detailed Information of the Advanced Box
Personal Space Operations
Folder Operations
Previewing a File
Operations for Files Stored in a Folder
Arranging Files and Folders Stored on the Network
Checking Storage Information
Folder Operations
Previewing a File
File Operations
Arranging Files and Folders Stored in Memory Media
Checking the Detailed Information for Memory Media
Folder Operations
Previewing a File
File Operations
Printing a Sample
Storing Print Settings
Adjusting Density During Printing
Merging Files When Printing
Favorite Settings
Storing Favorite Settings
Recalling/Deleting Favorite Settings
Paper Selection
Collating Prints
Two-Sided Printing
Convenient Modes for Printing
Adding a Cover
Inserting Sheets
Booklet Mode
Job Separator
Shifting the Original Image Using the Numeric Keys
Adding a Secure Watermark
Document Scan Lock
Document Scan Lock
Superimpose Image
Gutter
Page Numbering
Copy Set Numbering
Watermark Printing
Date Printing
Print on Tab
Adjusting the Print Resolution
Printing with Halftones
Adjusting Printing to Fit the Paper Size
Enlarging the Print Area
Printing Files with Multiple Pages on One Page (N On 1)
Printing Comments
Printing Password Protected PDF Files
Enlarging and Reducing Prints
Setting the Print Orientation
Setting the Print Position
Sending a File
Unavailable Combination of Functions
Top » Access Stored Files » Booklet Mode
Booklet Mode
08KE-16W
This mode enables you to print documents in such a way that the prints are made into a booklet.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
For information on the Booklet Scan mode, see "Booklet Scanning."
Saddle Stitch Booklet
This mode enables you to print one-sided or two-sided files in such a way that the prints are made into a booklet.
When the Booklet Finisher-Q1 PRO/Booklet Finisher-N1 is attached
Divided Booklet
This mode enables you to make a large document with many pages into a divided booklet.
Creep (Displacement) Correction
This mode enables you to adjust the position of the images in a booklet by calculating the width of the displacement between the outermost page and center page of the booklet
*1 Trimmed
*2 After the pages are trimmed, the outer margins of all pages are equal.
*3 The inner margins are set so that the inner margins of the outermost pages are wider than the inner margins of the center pages. The placement of the images on each page is adjusted by calculating the amount of displacement between the outermost page and innermost page of the booklet.
If the Trim Mode Is Set:
The edges of Saddle Stitched sheets are trimmed.
As an example, the procedure for printing files that are stored in a Mail Box is explained in this section.
This mode can be used only for printing a file stored in a mail box or a PDF or XPS file.
The Saddle Stitch and Divided Booklet modes can be set only if the Booklet Finisher-Q1 PRO/Booklet Finisher-N1 is attached.
You can set [Trim] only if the Inner Booklet Trimmer-D1 is attached to the Booklet Finisher-Q1 PRO or Inner Booklet Trimmer-A1 is attached to the Booklet Finisher-N1.
You can set [Trim] only if you select [Fold + Saddle Stitch].
Be sure to correctly set the paper type. When printing on special types of paper, such as heavy paper, be sure to correctly set the paper type, especially if you are using heavy paper. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
[Booklet Scan] can only be specified for the following paper sizes: LTR, LTRR, STMT, or STMTR.
The Booklet mode cannot be set if multiple files are selected, and their record sizes are different.
Press [Access Stored Files] → [Mail Box].
Select the desired Mail Box → select the desired file → press [Print].
Press [Change Print Settings].
4.
Press [Options] → [Booklet].
5.
Specify the booklet print settings.
Mail Box
Advanced Box/Network/Memory Media
Folding and Saddle Stitching:
Adding Covers:
Changing the Layout Size of a Booklet:
Press [Fold + Saddle Stitch].
If you do not want to saddle stitch, select [Fold Only].
If you do not want to set the Fold and Saddle Stitch modes, select [Do Not Fold].
Fold can be used only for printing a file stored in a mail box.
If the Booklet Finisher-Q1 PRO is attached, the maximum number of sheets, including cover sheets, that can be saddle stitched is 20. If the number of sheets is 21 or more, the booklet is not saddle stitched.
When the Booklet Finisher-Q1 PRO is attached, if you want to saddle stitch 21 or more sheets, set the Divided Booklet mode.
If the Booklet Finisher-N1 is attached, the maximum number of sheets, including cover sheets, that can be saddle stitched is 16. If the number of sheets is 17 or more, the booklet is not saddle stitched.
When the Booklet Finisher-N1 is attached, if you want to saddle stitch 17 or more sheets, set the Divided Booklet mode.
If you select [Fold Only], a maximum of five sheets can be folded at a time for the Booklet Finisher-Q1 PRO, and only one sheet can be folded at a time for the Booklet Finisher-N1.
Adding Covers:
Press [Add Cover] → [Print].
Press [Leave Blank] if you do not want to print on the cover.
If you are feeding cover paper from the Document Insertion Unit-K1, select [Leave Blank].
If you selected [Booklet Scan], you can set <Front Cover>, <Front Inside Cover>, <Back Inside Cover>, and <Back Cover> individually.
To set the paper for the cover, press [Change] → select the paper source → press [OK].
If you want to select the multi-purpose tray when a paper size/type is already selected for the current or reserved job, press [Change MP Tray Paper].
You must select the same paper size for the cover page as that used for the main document.
If you are loading preprinted paper to use as the cover page into the document insertion unit, you must load the paper face up.
If you are using Heavy 3 paper, you can only print on <Front Inside Cover> or <Back Inside Cover>.
When using Booklet Finisher-Q1 PRO, use the paper shown below.
Main document: 14 lb bond to 140 lb index (52 to 256 g/m2)
Cover page: 17 lb bond to more than 140 lb index (64 to more than 256 g/m2)
When using Booklet Finisher-N1, use the paper shown below.
Main document: 16 lb bond to 80 lb cover (60 to 220 g/m2)
Cover page: More than the paper weight of main document, and 16 lb bond to 140 lb index (60 to 256 g/m2) or more
[Add Cover] can be used only for printing a file stored in a mail box.
Press [Change] for <Layout Size>.
Select the desired booklet size → press [OK].
6.
Press [Set Details] → specify the detailed Booklet settings.
If you do not want to specify the detailed settings, proceed to step 7.
Making a divided booklet:
Setting the creep correction:
Trimming the edges of the booklet:
Adjusting the trim width:
Adjusting the saddle stitch position:
Adjusting the fold position:
[Set Details] can be used only for printing a file stored in a mail box.
Press [Divided Booklet] → set the number of sheets to divide → press [OK].
If the Booklet Finisher-Q1 PRO is attached, the maximum number of sheets, including cover sheets, that can be saddle stitched is 25. If the number of sheets is 26 or more, the booklet is not saddle stitched.
If the Booklet Finisher-N1 is attached, the maximum number of sheets, including cover sheets, that can be saddle stitched is 20. If the number of sheets is 21 or more, the booklet is not saddle stitched.
If the Booklet Finisher-Q1 PRO is attached, the number of saddle stitched booklets that the auxiliary booklet tray can hold depends on the number of sheets each booklet contains, paper size, and whether the booklet includes cover page used heavy paper (more than 21 lb bond (more than 81 g/m2)).
Number of Sheets to Use
Number of Prints the Auxiliary Booklet Tray Can Hold
Using paper other than A4R/LTRR with heavy paper (21 lb bond or more (81 g/m2 or more)) for cover
Using paper other than A4R/LTRR without heavy paper (21 lb bond or more (81 g/m2 or more)) for cover
Using A4R/LTRR Paper
1 to 5 sheets:
30 sets
25 sets
20 sets
6 to 10 sheets:
25 sets
20 sets
15 sets
11 to 15 sheets:
15 sets
15 sets
10 sets
16 to 20 sheets:
15 sets
10 sets
10 sets
20 to 25 sheets:
10 sets
10 sets
10 sets
If the Booklet Finisher-N1 is attached, the number of saddle stitched booklets that the auxiliary booklet tray can hold depends on the number of sheets each booklet contains.
1 to 5 sheets:
25 sets
6 to 10 sheets:
15 sets
11 to 16 sheets:
10 sets
17 to 20 sheets:
5 sets
If [Fold Only] is selected, a maximum of five sheets of paper are folded.
If the Booklet Trimmer-D1 is attached to the Booklet Finisher-Q1 PRO, the tray can hold 30 prints.
Press [Creep Correction] → select the correction method → press [OK] → [OK].
If you select [Manual], press or to adjust the correction width.
Press [Trim].
Press [Adjust Trim Width] → adjust the trim width → press [OK].
Press [Change Fold/Stitch Pos.] → select the paper size for finishing.
Adjust the saddle stitch position using [-] or [+]→ press [OK] → [OK].
You can set [Change Fold/Stitch Pos.] only if you select [Fold + Saddle Stitch].
If you want to adjust the folding position, press [Adjust Fold Position] → adjust the folding position → press [OK].
You can set [Adjust Fold Position] only if you select [Fold Only].
7.
Press [OK] → [Close].
Saddle stitching is not performed if there is only one output sheet.
The accuracy of folds may vary, depending on the type and quantity of paper.
