This mode can be used only for printing a file stored in a mail box or a PDF or XPS file.
The Saddle Stitch, Fold, Trim, and Face Up/Down Setting modes can be used only for printing a file stored in a mail box.
Be sure to correctly set the paper type. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty, or the paper could jam, and a service repair may be needed.
The Finishing modes cannot be set if free size, transparencies, tracing paper, or labels is selected.
If you set the Staple, Hole Punch, or Z-Fold mode, the side of the paper which is printed on will always be output face down.
The paper used for the cover page must be the same size as that which is used for the main document.
If you are loading preprinted paper to use as the cover page into the document insertion unit, you must load the paper face up.
When using Booklet Finisher-Q1 PRO, use the paper shown below.
Main document: Main document: 14 lb bond to 140 lb index (52 to 256 g/m2)
Cover paper: More than the paper weight of main document, and 17 lb bond to 140 lb index (64 to 256 g/m2) or more
When using Booklet Finisher-N1, use the paper shown below.
Main document: 16 lb bond to 80 lb cover (60 to 220 g/m2)
Cover paper: More than the paper weight of main document, and 16 lb bond to 140 lb index (60 to 256 g/m2) or more
The [Saddle Stitch] mode can be set only if 2-Sided Copying is set.
The accuracy of folds created in the Saddle Stitch mode may vary, depending on the paper type and the number of sheets.
If you specify the Z-Fold mode with the Staple mode, and the number of sheets that are Z-folded exceeds 10, the prints will be collated, but not stapled.
If you want the printed side to be folded inside, select [Up (Reverse Order)] for [Face Up/Face Down].
The Saddle Stitch mode can be set only if the two-Sided Print is set.
A maximum of five sheets can be folded together and output with Saddle Fold.
[Auto]:
If you are printing a single page original, the printed sheets are output face up. Otherwise, the printed sheets are output face down.
[Face Down (Normal Order)]:
Printed sheets are always output face down.
[Face Up (Reverse Order)]:
Printed sheets are always output face up.
You can set [Trim] only if you select [Saddle Stitch].
Optional Unit
Collate (Page Order)
Group (Same Pages)
Offset
Staple
Hole Punch
Fold
Trim
Face Up/Face Down
Corner
Double
Saddle Stitch
Saddle Fold
Z-Fold, C-Fold, Half Fold, Accordion Z-Fold, Double Parallel Fold
None
Staple Finisher-Q1 PRO
Staple Finisher-Q1 PRO and Puncher Unit
Staple Finisher-Q1 PRO, Professional Puncher-C1, and Professional Puncher Integration Unit-B1
Staple Finisher-Q1 PRO and Paper Folding Unit-H1
Booklet Finisher-Q1 PRO and Puncher Unit
Booklet Finisher-Q1 PRO, Professional Puncher-C1, and Professional Puncher Integration Unit-B1
Booklet Finisher-Q1 PRO and Paper Folding Unit-H1
Booklet Finisher-Q1 PRO and Inner Booklet Trimmer-A1
Optional Unit
Group (Same Pages)
Offset
Staple
Hole Punch
Fold
Trim
Face Up/Face Down
Corner
Double
Saddle Stitch
Saddle Fold
Z-Fold, C-Fold
None
Staple Finisher-N1
Staple Finisher-N1 and Puncher
Staple Finisher-N1 and Professional Puncher Integration Unit-B1
Staple Finisher-N1 / Paper Folding Unit-H1
Booklet Finisher-N1
Booklet Finisher-N1 and Puncher
Booklet Finisher-N1 and Professional Puncher Integration Unit-B1
Booklet Finisher-N1 / Paper Folding Unit-H1
Booklet Finisher-N1 / Inner Booklet Trimmer-A1
Paper Size
Corner
Double
Saddle Stitch*
13" x 19"
25 sheets
12" x 18"
25 sheets
12 5/8" x 17 11/16"
25 sheets
11" x 17"
50 sheets
50 sheets
25 sheets
LGL
50 sheets
50 sheets
25 sheets
LTRR
50 sheets
50 sheets
25 sheets
LTR
100 sheets
100 sheets
EXEC
100 sheets
100 sheets
STMTR
STMT
Paper Size
Corner
Double
Saddle Stitch*
12" x 18"
20 sheets
12 5/8" x 17 11/16"
20 sheets
11" x 17"
50 sheets
50 sheets
20 sheets
LGL
50 sheets
50 sheets
20 sheets
LTRR
50 sheets
50 sheets
20 sheets
LTR
100 sheets
100 sheets
EXEC
100 sheets
100 sheets
STMTR
STMT
For information on the original orientation and paper orientation when performing stapling, see "Relationship Between the Original Orientation and Paper Orientation."
For information on the custom size paper can be stapled, see "Staple Finisher-Q1 PRO/Booklet Finisher-Q1 PRO/Puncher Unit-BS1."
For information on optional products, see the following:
If [Finishing] is not set, the settings are the same as when [Group (Same Pages)] is set.
You can display the detailed information of the selected paper by pressing
