Category Top
Overview of This Function
Advanced Box/Network Settings
Mail Box
Advanced Box
Network
Memory Media
Flow of Operations for Accessing Stored Files
Printing Files Stored in a Mail Box
Printing Files Stored in the Advanced Box
Printing Files Stored on the Network
Printing Files Stored in Memory Media
Canceling a Job While Printing
Reserving Jobs
Arranging Files Stored in a Mail Box
Checking File Information
Previewing a File
Operations for Files Stored in a Mail Box
Printing Lists
Arranging Files and Folders Stored in the Advanced Box
Checking Detailed Information of the Advanced Box
Personal Space Operations
Folder Operations
Previewing a File
Operations for Files Stored in a Folder
Arranging Files and Folders Stored on the Network
Checking Storage Information
Folder Operations
Previewing a File
File Operations
Arranging Files and Folders Stored in Memory Media
Checking the Detailed Information for Memory Media
Folder Operations
Previewing a File
File Operations
Printing a Sample
Storing Print Settings
Adjusting Density During Printing
Merging Files When Printing
Favorite Settings
Storing Favorite Settings
Recalling/Deleting Favorite Settings
Paper Selection
Collating Prints
Two-Sided Printing
Convenient Modes for Printing
Adding a Cover
Inserting Sheets
Booklet Mode
Job Separator
Shifting the Original Image Using the Numeric Keys
Adding a Secure Watermark
Document Scan Lock
Document Scan Lock
Superimpose Image
Gutter
Page Numbering
Copy Set Numbering
Watermark Printing
Date Printing
Print on Tab
Adjusting the Print Resolution
Printing with Halftones
Adjusting Printing to Fit the Paper Size
Enlarging the Print Area
Printing Files with Multiple Pages on One Page (N On 1)
Printing Comments
Printing Password Protected PDF Files
Enlarging and Reducing Prints
Setting the Print Orientation
Setting the Print Position
Sending a File
Unavailable Combination of Functions
Top » Access Stored Files » Superimpose Image
Superimpose Image
08KE-173
This mode enables you to superimpose a previously scanned image (image form) registered in the machine's memory on the output.
This mode can be used only for printing a file stored in a mail box.
To use the Superimpose Image mode, the image form must be registered in the machine beforehand. (See "Registering Forms for the Superimpose Image Mode.")
Press [Access Stored Files] → [Mail Box].
Select the desired Mail Box → select the desired file → press [Print].
Press [Change Print Settings].
4.
Press [Options] → [Superimpose Image].
5.
Press [Set] for the side of the paper you want to superimpose.
<Back Side> can only be selected for a two-sided print.
To specify the same settings as <Front Side> for <Back Side>, press [Same as Front Side].
6.
Select the image form to be superimposed over the original → press [OK].
To print and check a registered image form, press [Check Print] → select the paper size → press [Start Printing].
Image forms stored in the RGB color format are indicated with a  icon. Image forms stored in the CMYK color format are indicated with a  icon. (Color image forms are indicated with a color icon.)
To check the detailed information for the selected image form, press [Details].
7.
Press [OK] → [Close].
If the size of the image form differs from the original, this mode may not operate correctly. Use the same size image form and original for this mode.
Printing performance may not be optimal, depending on the content of the file and image form.
The moiré effect (a shimmering, wavy pattern) may occur, depending on the content of the file and image form.
You can register up to 100 image forms. However, this number varies depending on the capacity of the hard disk.
The Superimpose Image mode cannot be used with files including images with resolutions of less than 600 x 600 dpi.
Print modes other than the Shift mode can only be used for printing images.
The Superimpose Image mode cannot be used if the resolution of the image form and file differ.
You cannot select image forms with differing resolutions for the back and front sides.
The check print is a sample print. The actual printout may vary slightly with the check print.
