Category Top
Overview of This Function
Advanced Box/Network Settings
Mail Box
Advanced Box
Network
Memory Media
Flow of Operations for Accessing Stored Files
Printing Files Stored in a Mail Box
Printing Files Stored in the Advanced Box
Printing Files Stored on the Network
Printing Files Stored in Memory Media
Canceling a Job While Printing
Reserving Jobs
Arranging Files Stored in a Mail Box
Checking File Information
Previewing a File
Operations for Files Stored in a Mail Box
Printing Lists
Arranging Files and Folders Stored in the Advanced Box
Checking Detailed Information of the Advanced Box
Personal Space Operations
Folder Operations
Previewing a File
Operations for Files Stored in a Folder
Arranging Files and Folders Stored on the Network
Checking Storage Information
Folder Operations
Previewing a File
File Operations
Arranging Files and Folders Stored in Memory Media
Checking the Detailed Information for Memory Media
Folder Operations
Previewing a File
File Operations
Printing a Sample
Storing Print Settings
Adjusting Density During Printing
Merging Files When Printing
Favorite Settings
Storing Favorite Settings
Recalling/Deleting Favorite Settings
Paper Selection
Collating Prints
Two-Sided Printing
Convenient Modes for Printing
Adding a Cover
Inserting Sheets
Booklet Mode
Job Separator
Shifting the Original Image Using the Numeric Keys
Adding a Secure Watermark
Document Scan Lock
Document Scan Lock
Superimpose Image
Gutter
Page Numbering
Copy Set Numbering
Watermark Printing
Date Printing
Print on Tab
Adjusting the Print Resolution
Printing with Halftones
Adjusting Printing to Fit the Paper Size
Enlarging the Print Area
Printing Files with Multiple Pages on One Page (N On 1)
Printing Comments
Printing Password Protected PDF Files
Enlarging and Reducing Prints
Setting the Print Orientation
Setting the Print Position
Sending a File
Unavailable Combination of Functions
Top » Access Stored Files » Printing Comments
Printing Comments
08KE-17J
You can add comments when printing PDF files.
As an example, the procedure for printing files that are stored in the Advanced Box is explained in this section.
This mode is only available for printing files stored in the Advanced Box, the Advanced Box of another imageRUNNER ADVANCE machine on the network, or memory media.
You can use this mode only when printing PDF files.
Press [Access Stored Files] → [Advanced Box].
Select the desired storage space → select the directory where the file you want to print is stored.
Select the desired file → press [Print].
4.
Press [Options] → [Print Comments].
To change the paper source, see "Paper Selection."
5.
Press [Auto] → [OK] → [Close].
Comments specified within the PDF file are printed together with the file.
If you do not want to print the comments, press [Do Not Print].
