Category Top
Overview of This Function
Advanced Box/Network Settings
Mail Box
Advanced Box
Network
Memory Media
Flow of Operations for Accessing Stored Files
Printing Files Stored in a Mail Box
Printing Files Stored in the Advanced Box
Printing Files Stored on the Network
Printing Files Stored in Memory Media
Canceling a Job While Printing
Reserving Jobs
Arranging Files Stored in a Mail Box
Checking File Information
Previewing a File
Operations for Files Stored in a Mail Box
Printing Lists
Arranging Files and Folders Stored in the Advanced Box
Checking Detailed Information of the Advanced Box
Personal Space Operations
Folder Operations
Previewing a File
Operations for Files Stored in a Folder
Arranging Files and Folders Stored on the Network
Checking Storage Information
Folder Operations
Previewing a File
File Operations
Arranging Files and Folders Stored in Memory Media
Checking the Detailed Information for Memory Media
Folder Operations
Previewing a File
File Operations
Printing a Sample
Storing Print Settings
Adjusting Density During Printing
Merging Files When Printing
Favorite Settings
Storing Favorite Settings
Recalling/Deleting Favorite Settings
Paper Selection
Collating Prints
Two-Sided Printing
Convenient Modes for Printing
Adding a Cover
Inserting Sheets
Booklet Mode
Job Separator
Shifting the Original Image Using the Numeric Keys
Adding a Secure Watermark
Document Scan Lock
Document Scan Lock
Superimpose Image
Gutter
Page Numbering
Copy Set Numbering
Watermark Printing
Date Printing
Print on Tab
Adjusting the Print Resolution
Printing with Halftones
Adjusting Printing to Fit the Paper Size
Enlarging the Print Area
Printing Files with Multiple Pages on One Page (N On 1)
Printing Comments
Printing Password Protected PDF Files
Enlarging and Reducing Prints
Setting the Print Orientation
Setting the Print Position
Sending a File
Unavailable Combination of Functions
Top » Access Stored Files » Inserting Sheets
Inserting Sheets
08KE-16U
This mode enables you to automatically add blank sheets, chapter pages, or tab paper to prints. You can use a different type of paper from that used for the main document. In addition, you can set whether to print on the sheet insertions and tab paper. Chapter pages are always printed on.
This is useful when you want to use a blank sheet to sort prints.
Sheet Insertion/Chapter Page
*1 Printed Chapter Page
*2 Printed Sheet Insertion
Tab Paper
This is convenient when sorting the body of documents etc.
* Printed Tab Paper
To print on the tab paper, set the shift width of the image to be printed on the tabs.
* Area Shifted Out
This mode can be used only for printing a file stored in a mail box.
Make sure to set the paper type correctly, especially when using heavy paper or other special types of paper. If the type of paper is not set correctly, it may adversely affect image quality. Moreover, the fixing unit may become dirty, or the paper could jam, and a service repair may be needed.
Press [Access Stored Files] → [Mail Box].
Select the desired Mail Box → select the desired file → press [Print].
Press [Change Print Settings].
4.
Press [Options] → [Insert Sheets].
5.
Select the type of sheet insertions → press [Add].
You cannot select [Sheets] and [Chapter Pages] at the same time.
6.
Specify the detailed settings for the sheet insertions → press [OK].
Set the pages to insert the sheets using - (numeric keys).
If you select [Sheets], set the number of sheets to insert and side(s) to be printed on.
Select [Sheet Inserter] for the sheet insertion tray to feed cover page from the Document Insertion Unit-K1. If you want to select the sheet inserter when a paper size/type is already set for the current or reserved job, you can press [Change Insert. Paper].
If you selected [Tab], set the print shift width (0" to 1" (0 mm to 25 mm)) using [-] or [+] → press [OK].
To select the paper for the sheet insertions, press [Change] for <Select Paper> → select the paper source → press [OK].
Repeat step 6 to specify the features as necessary.
If you set a different paper size for the front cover, back cover, or sheet insertions, the paper sizes for the other features are automatically changed to the new paper size. However, changing the paper source for a feature to a source with the same paper size does not change the settings for the other features.
If you select [Tab], only LTR paper can be used.
If [Print on Both Sides] is selected for the front cover in [Add Cover] and tab paper is set to insert in front of the first page, the front cover is output first, and then the tab paper is output. The front cover outputs as a blank paper and prints are made starting from the tab paper.
If you select [Leave Blank] for the sheet insertion, you can set the same page for tab paper. In this case, the paper for the sheet insertion is output first, and then the tab paper is output.
You can insert a total of up to 100 sheet insertions or chapter pages.
If you are using paper that already has printing on it (e.g., company logo) as your sheet insertion, then you must select [Leave Blank]. Otherwise, the machine will print on the preprinted paper.
7.
Press [OK] → [Close].
You can confirm/change the settings for sheet insertions, chapter pages, tab paper by pressing [Details/Edit] after selecting the settings.
To delete a sheet insertion, select the setting to delete → press [Delete].
Make sure that the Number of Tabs shown on the touch panel display is the same as the number of tabs on the tab paper loaded in the paper source.
If [Staple] is selected, for the total number of sheets that can be stapled, including sheet insertions and chapter pages, see "Maximum Number of Sheets You Can Staple."
You cannot select multiple files and specify sheet insertion settings for the files at the same time. In this case, set the Job Separator mode. (See "Job Separator.")
If you are printing on the sheet insertions, these sheets are included in the count of the total number of prints made. However, if these sheets are left blank, the machine's counter does not count them as prints.
If you add chapter pages, these sheets are included in the count of the total number of prints made.
If you want to set both [Insert Sheets] and [Add Cover], select the same paper size.
Tab paper is always printed on. If you do not want to print on the tab paper, insert blank sheets of paper in each place where you want the tab paper to go.
When printing on tab paper, check that the position of the tabs is correct.
If you are feeding tab paper from the paper drawer, you must register the paper type in the paper source as tab paper beforehand. (See "Registering the Paper Size and Type for a Paper Source.")
For instructions on loading tab paper into the paper drawer or Document Insertion Unit-K1, see "Loading Tab Paper" or "Loading Paper into the Document Insertion Unit-K1 (Optional)."
If [Unfinished Tab Paper Forced Output] in [Function Settings] (Settings/Registration) is set to 'On', the extra amount of tab paper sheets that were not required for the job are forced out of the machine.
Example: If the number of tabs is set to 5 and the machine estimates that seven sheets of tab paper are needed for the print job, you must prepare two sets of tab paper each containing five tabs (10 total). Therefore, if the machine only uses seven tab paper sheets, three tab paper sheets will remain.
Areas of images shifted outside the tab paper cannot be printed on the paper, and may cause the following prints to have black streaks or appear dirty.
* Area Shifted Out
