Category Top
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Paper Output
Print Quality
Layout
Auto Continue
Secure Print Delete Time
Timeout
Print After Completing RIP
Booklet
Saddle Stitch
Creep Correction
Use Cover Inserter
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Initialize
UFR II Settings
Halftones
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
PS Settings
Job Timeout
Print PS Errors
Halftones
Grayscale Conversion
Dot Gain Adjustment
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Halftones
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Halftones
Dot Gain Adjustment
XPS Settings
Halftones
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Top » Print » Bar Code Printing » Troubleshooting » List of Error Messages
08KE-1KC
This section explains the various error messages that could be generated, along with their possible causes and remedies.
If an error message occurs, an X is printed on top of the bar code, and the error message appears automatically under the bar code.
!Err: Char=nn
Symbologies: All
Cause
An invalid character was entered. 'nn' is the ASCII value of that character. This error occurs if you include a letter in a bar code that requires numeric data only, such as EAN or 25.
Remedy
Verify the data for the bar code.
!Err: Odd
Symbologies: 2 of 5 Interleaved, Code 128C
Cause
The string you tried to print in the 2 of 5 Interleaved format has an odd number of digits. With the 2 of 5 Interleaved and Code 128C bar codes, digits are paired in groups. Note that if you use the 2 of 5 Interleaved bar code with a checksum calculation, you must send an odd number of digits, as the checksum digit will be rounded to an even number of digits.
Remedy
Verify the string size, and send an even or odd number of digits.
!Err: Length
Symbologies: All
Cause
An invalid length of data was entered for the bar code. This means that the data string is too short or too long.
Remedy
Verify that the data length conforms to the symbology specifications. (See "Sizing Parameters.")
!Err: NonZero and !Err: InvVal
Symbology: UPC-E
Cause
The Bar Code Printing function found an unexpected value in the UPC-E bar code.
Remedy
Make sure that there is a minimum of four zeros, and verify that the data conforms to the UPC-E symbology specifications. (See "1D Bar Codes.")
!Err: R/A/B
Symbology: French Postal 39 A/R
Cause
The string supplied to the Bar Code Printing function to generate the French Postal 39 bar code does not start with 'RA' or 'RB'.
Remedy
Verify that the data for the bar code conforms to the French Postal 39 symbology specifications. (See "1D Bar Codes.")
!Err: Fmt=00000000
Symbology: Australia Post 4 State 37-CUST
Cause
The Australia Post 4 State 37-CUST bar code encodes the DPID, an eight digit number. The DPID string supplied to the Bar Code Printing function to generate the 37-CUST bar code does not consist of eight digits.
Remedy
Verify the length of the DPID string. (See "1D Bar Codes.")
!Err: Fmt=00000000,<CustInfo>
Symbologies: Australia Post 4 State 52-FF-MET and 67-FF-MET
Cause
The Australia Post 4 State 52-FF-MET and 67-FF-MET bar codes encode the DPID, an eight digit number, and the customer information, which can be encoded using the N table if it only includes digits. Either the DPID string does not consist of eight digits, or there is no customer information defined in the string, or the comma separator is missing.
Remedy
Verify that the data for the bar code conforms to the symbology specifications. (See "1D Bar Codes.")
!Err: CustInfo: nonDigit
Cause
The Australia Post 4 State 52-FF-MET and 67-FF-MET bar codes encode the DPID, an eight digit number, and the customer information, which can be encoded using the N table if it only includes digits. The customer information defined in the string supplied to the Bar Code Printing function includes at least one character that is not a digit.
Remedy
Verify the customer information data for the bar code, and make sure that the data conforms to the symbology specifications. (See "1D Bar Codes.")
!Err: CustInfo>NN (where NN is a value)
Cause
The customer information section of the 52-FF-MET and 67-FF-MET bar codes has a defined maximum length depending on the N or C encoding table of the p parameter. The customer information defined in the string supplied to the Bar Code Printing function exceeds its maximum length.
Remedy
The maximum length is NN based on the encoding table of the p parameter. Make sure the customer information data adheres to this specification.
!Err: InvCharInCustInfo
Cause
The customer information section of the 52-FF-MET and 67-FF-MET bar codes includes a predefined set of characters. The customer information defined in the string and supplied to the Bar Code Printing function, includes illegal characters.
Remedy
Verify the customer information data, and make sure that there are no illegal characters.
!Err: Codablock size
Symbologies: Codablock
Cause
The number of rows and columns indicated in the escape sequence do not leave enough room for data encoding.
Remedy
Increase the size of the columns and rows so that the encoded data fits properly. (See "2D Bar Codes.")
