Category Top
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Paper Output
Print Quality
Layout
Auto Continue
Secure Print Delete Time
Timeout
Print After Completing RIP
Booklet
Saddle Stitch
Creep Correction
Use Cover Inserter
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Initialize
UFR II Settings
Halftones
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
PS Settings
Job Timeout
Print PS Errors
Halftones
Grayscale Conversion
Dot Gain Adjustment
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Halftones
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Halftones
Dot Gain Adjustment
XPS Settings
Halftones
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Top » Print » Bar Code Printing » Menus and Their Functions
08KE-1K4
When the Bar Code Printing function is activated, the BarDIMM and FreeScape menus become available in the PCL/PS menu.
Accessing the Menus
Follow the procedure below to access the BarDIMM or FreeScape menu.
Press [Function Settings] → [Printer] → [Printer Settings].
Press [Custom Settings] → press or until [PCL] appears → press [PCL].
4.
Press or until [BarDIMM] or [FreeScape] appears → select [BarDIMM] or [FreeScape].
BarDIMM Menu
Enable, Disable*
This setting enables you to print bar codes supported by the Barcode Printing Kit.
If [Enable] is selected, the machine will generate bar codes when it receives bar code commands from the host computer.
If [Disable] is selected, bar codes will not be generated, even if bar code commands are sent from the host computer.
To enable the BarDIMM menu, it is necessary to activate the Barcode Printing Kit.
When you are not printing bar codes, make sure to disable the BarDIMM menu. Otherwise, the processing speed of regular print jobs may be reduced.
The default setting is [Disable]. If you activate the Barcode Printing Kit, it changes to [Enable].
[FreeScape] appears only if the BarDIMM menu is enabled.
FreeScape Menu
Off, ~*, ", #, $, /, \, ?, {, }, |
You can specify the AEC (Alternate Escape Code) to be used for bar code commands when the host computer does not support the standard Escape Code.
Make sure that the Bar Code Printing function is enabled before you print bar codes.
When the Bar Code Printing function is activated, [BarDIMM] and [FreeScape] appear on the Configuration Page (from the Settings/Registration screen).
For more information on using the touch panel display, see "Menu Functions."
You can specify settings from your computer using the Remote UI function of your machine. For more information, see "Managing Copy/Print Jobs."
An asterisk (*) indicates the default setting.
