e-Manual
Top
Site map
Help
Glossary
Contents
Search
Previous
Next
Print this topic
Category:
Before You Start Using This Machine
Flow of Settings
Basic Operations
Optional Products/Software
Settings/Registration
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Status Monitor/Cancel
Print
Network
Remote UI
MEAP
Security
Practical Workflows
How to Use This Manual
Expand All
Collapse All
Category Top
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Paper Output
Print Quality
Layout
Auto Continue
Secure Print Delete Time
Timeout
Print After Completing RIP
Booklet
Saddle Stitch
Creep Correction
Use Cover Inserter
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Initialize
UFR II Settings
Halftones
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
PS Settings
Job Timeout
Print PS Errors
Halftones
Grayscale Conversion
Dot Gain Adjustment
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Halftones
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Halftones
Dot Gain Adjustment
XPS Settings
Halftones
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Print all
Keyword:
Search options
Search all categories
Search from below categories
Flow of Settings
Basic Operations
Maintenance
Problem Solving
Copy
Fax
Scan and Send
Scan and Store
Access Stored Files
Fax/I-Fax Inbox
Secure Print
Hold
Web Access
Scanner
Quick Menu
Print
Network
Remote UI
MEAP
Security
Practical Workflows
Case sensitive
Differentiate between one-byte and two-byte
Search with these conditions
Specify search conditions
Search Method
Top
Print
XPS Settings
XPS Settings
08KE-1J4
Settings on this menu specify how to print XPS files that are sent directly to the machine using the Remote UI or command prompt.
Halftones
These settings are only applicable for the XPS Direct Print Printer.
Back to Top
