Category Top
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Paper Output
Print Quality
Layout
Auto Continue
Secure Print Delete Time
Timeout
Print After Completing RIP
Booklet
Saddle Stitch
Creep Correction
Use Cover Inserter
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Initialize
UFR II Settings
Halftones
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
PS Settings
Job Timeout
Print PS Errors
Halftones
Grayscale Conversion
Dot Gain Adjustment
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Halftones
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Halftones
Dot Gain Adjustment
XPS Settings
Halftones
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » PCL Settings » Enlarge A4 Print Width
08KE-1H4
[On], [Off]*
This setting determines whether to expand the printable area of A4 size paper to that of Letter size in width.
[On]
All the area on a page 1/6" from the top and bottom edges and 1/8" from the left and right edges is available for printing on A4 paper. Only the width increases.
[Off]
All the area on a page 1/6" from the top, bottom, left, and right edges is available for printing on A4 paper.
Settings
On
Off
A: Length
11 1/3"
B: Width
8"
7 7/8"
C: Left and right edges
1/8"
1/6"
D: Top and bottom edges
1/6"
This setting is applicable for A4 paper only.
This setting is applicable for portrait orientation only.
