Category Top
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Paper Output
Print Quality
Layout
Auto Continue
Secure Print Delete Time
Timeout
Print After Completing RIP
Booklet
Saddle Stitch
Creep Correction
Use Cover Inserter
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Initialize
UFR II Settings
Halftones
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
PS Settings
Job Timeout
Print PS Errors
Halftones
Grayscale Conversion
Dot Gain Adjustment
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Halftones
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Halftones
Dot Gain Adjustment
XPS Settings
Halftones
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » Printing Problems
Printing Problems
08KE-1JC
If you have trouble printing, we recommend resolving the problems with the following remedies.
Please contact your local authorized Canon dealer if a problem persists, or if you encounter problems not listed below.
Printer Trouble
The printer's function does not work.
Cause 1
There is data remaining in the printer's memory. (The Processing/Data indicator is blinking or lit.)
Remedy
Print out the data.
Cause 2
There is a problem with the printer or the software.
Remedy
Look at the message on the display and act accordingly. (See "Printer.")
Printing stops before the job is complete.
Cause
Remedy
Print out the data.
You cannot print a job or store a job.
Cause
The total number of pages in all jobs (maximum capacity is 20,000 pages) or size of data in the memory has exceeded the limit which can be processed.
Remedy 1
Delete other processes or documents stored in the box, cancel other jobs being processed, or wait until those jobs are finished, then print again.
Remedy 2
Divide the job, then print again.
You cannot store a secure print job.
Cause
The number of secured jobs stored in the machine has exceeded the maximum capacity of 50 jobs, or the total number of pages that are stored or are in jobs has exceeded the limit (20,000 pages).
Remedy
Delete other secured jobs, or wait until those jobs have finished printing, then print again.
The color plate is not aligned. (The paper color is seen on the border due to a misaligned color plate.)
Cause
Change the Special Smoothing Mode settings.
Remedy
Change your printer driver settings to the following, and perform printing.
Set the Resolution to [Fine].
Set the Special Smoothing Mode to one of six modes, [Mode 1] to [Mode 6].
Printing Problems
Meaningless characters are being printed.
Cause 1
You have printed from Windows without installing the printer driver for Windows that was included with the machine.
Remedy
Install the printer driver for Windows that was included with the machine and print the data again. (See the Driver Installation Guide.)
Cause 2
MS-DOS application software printer settings are incompatible.
Remedy
Reset the MS-DOS application software printer settings on a printer that is compatible with the machine. (See the application software manual.)
A font that is different from the one specified is printed.
Cause
The 'Send According to Font Substitution Table' setting has been set on the printer driver for Windows.
Remedy
Set the 'Send According to Font Substitution Table' setting to the correct setting and print the data again. (See the Help function on the printer driver.)
You cannot print the last page.
Cause
The command that identifies the end of the data has not been sent from the computer
Remedy
Clear the print data. (If you print from application software that lacks a print function and the last page of data is not a full page, the data will remain in the machine's memory.)
A print job that you have specified as two-sided printing is printed on one side of the paper.
Cause 1
The paper size you have specified is not supported by two-sided printing.
Remedy
Change the print job settings and print the data again.
Cause 2
The settings for the front and back sides of the paper are different.
Remedy
The data does not fit on the page properly.
Cause 1
The paper is not in the correct position.
Remedy
Make sure the machine is set correctly and try printing again. (See "Maintenance.")
Cause 2
The data is outside the printable area.
Remedy 1
Insert margins around the data and print the data again. (See the Help function on the printer driver or the application software manual.)
Remedy 2
Change the 'Scaling' settings on the printer driver and print the data again. (See the Help function on the printer driver.)
The printing location has slipped.
Cause 1
[Gutter], [Offset Short Edge (Front)], [Offset Long Edge (Front)], [Offset Short Edge (Back)], or [Offset Long Edge (Back)] in the printer settings menu have been changed.
Remedy
Set [Gutter], [Offset Short Edge (Front)], [Offset Long Edge (Front)], [Offset Short Edge (Back)], and [Offset Long Edge (Back)] to '0.00' and print the data again. (See "Gutter," "Offset Short Edge/Offset Long Edge (Front)," and "Offset Short Edge/Offset Long Edge (Back).")
Cause 2
The application software's top margin and paper location settings are not correct.
Remedy
Set the correct settings for the top margin and the paper location and print the data again. (See the application software manual.)
Data that should be printed on the same page is printed on two separate pages.
Cause 1
The application software's 'Line spacing' and 'Number of lines on a page' settings are not correct.
Remedy
Change the settings so that the data fits on one page and print the data again. (See the application software manual.)
Cause 2
The Timeout setting is too short, when you set [Personality] to [Auto].
Remedy
Change the Personality setting to a setting other than [Auto], or increase the Timeout setting. (See "Personality" and "Timeout.")
Print Quality Problems
The printout is too light or too dark.
Cause 1
The toner density settings are not correct.
Remedy
Adjust the toner density and print the data again. (See "Density.")
Cause 2
[Toner Save] is set to [On].
Remedy
Set 'Toner Save' to 'Off' in the printer driver and print the data again. (See the Help function on the printer driver.)
You can also perform the same procedure from the touch panel display. (See "Density.")
Fine lines and characters with a small point size are light.
Cause
The specified thin lines and fine characters cannot be processed properly.
Remedy 1
Set [Resolution] to [600 dpi] and print the data again.
Remedy 2
Set 'Line Refinement' to [On] and print the data again.
