Category Top
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Paper Output
Print Quality
Layout
Auto Continue
Secure Print Delete Time
Timeout
Print After Completing RIP
Booklet
Saddle Stitch
Creep Correction
Use Cover Inserter
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Initialize
UFR II Settings
Halftones
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
PS Settings
Job Timeout
Print PS Errors
Halftones
Grayscale Conversion
Dot Gain Adjustment
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Halftones
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Halftones
Dot Gain Adjustment
XPS Settings
Halftones
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Top » Print » Bar Code Printing » Bar Code Format Parameters
08KE-1K8
This section describes the different bar code parameters.
Default Parameters
Bar Code Name
Height*1
Text-Flag
Bar Width 1*3
Bar Width 2*3
Bar Width 3*3
Bar Width 4*3
Space Width 1*3
Space Width 2*3
Space Width 3*3
Space Width 4*3
UPC-A
74
3
8
16
24
32
8
16
24
32
UPC-E
29
3
8
16
24
32
8
16
24
32
EAN-8
50
3
8
16
24
32
8
16
24
32
EAN-13
62
3
8
16
24
32
8
16
24
32
CODE 2/5
29
1
6
18
6
18
CODE 39
29
1
6
18
6
18
39 EXT
29
1
6
18
6
18
CODE 93
29
1
6
18
6
18
93 EXT
29
1
6
18
6
18
CODE 128
29
1
6
12
18
24
6
12
18
24
EAN 128
29
1
6
12
18
24
6
12
18
24
UCC 128
29
105
6
12
18
24
6
12
18
24
CODABAR
29
1
6
12
6
12
MSI PLESSEY
29
1
6
12
6
12
ZIP+4
9*2
1*2
USPS Tray Label
50.4
4
9*2
27*2
9*2
27*2
USPS Sack Label
50.4
1
9*2
27*2
9*2
27*2
German Postal 25
72
124
10
30
10
30
French Postal 39
36*2
124*2
7*2
21*2
7*2
21*2
Singapore 4 State
13.5*2
1*2
UK 4 State
13.5*2
1*2
Netherlands KIX
13.5*2
1*2
Australia 4 State
13.5*2
MaxiCode
1"x1"
PDF-417
Auto
Data Matrix
Auto
QRCode 1/2
Auto
Aztec
Auto
Codablock
16
1
6
12
18
24
6
12
18
24
OMR Marks
45
7
14
7
14
*1 Height is in pointsize.
*2 Cannot be overridden by the user.
*3 Bar Width / Space Width is in dots.
Height corresponds to the h parameter, TextFlag to the p parameter, and the four bar widths to the b parameter.
Height is in increments of 1/60", and bar widths are in increments of 1/600".
Sizing Parameters
Bar Code Type
Characters Encoded*1
Input Length*2*3
Character Width*4
Compression
Start/Stop Size*5 (in Thin Bar)
Checksums
UPC-A
D
11
7
No
11
1
UPC-E
D
11 or 6
3, 5 (for 11)
7 (for 6)
Yes (for 11)
14, 5 (for 11)
11 (for 6)
1 (for 11)
EAN/JAN-8
D
7
7
No
11
1
EAN/JAN-13
D
12
7
No
11
1
Supplemental 2 or 5 for EAN/UPC
D
2 or 5
9
No
13
0
CODE 39
DPU
1 to 99
16
No
32
1*6
39 EXT
DPULC
1 to 99
DU: 16
PLC: 32
No
32
1*6
Interleaved 2/5
D
2 to 100
9
Yes
12
1*6
Industrial 2/5
D
2 to 100
14
No
20
1*6
Matrix 2/5
D
1 to 99
10
No
18
1*6
EAN-128
DPUCL
1 to 99
Data dependent
Yes
>= 35
1
Code 128 Auto
DPUCL
1 to 99
Data dependent
Yes
24
1
Code 128A
DPUC
1 to 99
11
No
24
1
Code 128B
DPUL
1 to 99
11
No
24
1
Code 128C
D
1 to 99
5, 5
Yes
24
1
UCC-128
D
1 to 99
5, 5
Yes
51, 5 (CHK)
2
Codabar/Monarch
DP
1 to 99
12
No
0
1*6
MSI PLESSEY
D
1 to 99
12
No
8
1*6 or 2
CODE 93
DPU
1 to 99
9
No
19
2
93 EXT
DPULC
1 to 99
DU: 9
PLC: 18
No
19
2
ZIP + 4
D
5, 9 or 11
29/600"
No
5/600" and 8/600"
1
Singapore 4 State
D
6
88/600"
No
22/600"
1
UK 4 State
DU
7, 8 or 9
88/600"
No
22/600"
1
NL KIX
DU
5 to 12
88/600"
No
22/600"
0
AP 37-CUST
D
8
44/600"
No
44/600"
1
AP 52-FF-MET
DUL
8 + 8D/5UL
44/600"
Yes (N table)
44/600"
1
AP 67-FF-MET
DUL
8 + 15D/10UL
44/600"
Yes (N table)
44/600"
1
Singapore ZIP + 4
D
5, 9 or 11
29/600"
No
5/600" and 8/600"
1
MaxiCode
DPLUC
Up to 100
Yes
Codewords
PDF-417
DPLUC
Up to 1,848
Yes
Codewords
Data Matrix
DPLUC
Up to 2,335
Yes
Codewords
Codablock
DPLUC
Up to 5,366
Data dependent
Yes
46
1
Aztec
DPLUC
Up to 3,832
Yes
Codewords
QRCode1/2
DPLUC
Up to 7,089
Yes
Codewords
*1 D = Digits, P = Punctuation, L = Lower case letters, U = Upper case letters, C = Control characters (ASCII 0 to 31)
*2 The checksum character is not counted.
*3 Unit = Number of characters
*4 Unit = Thin Bar Width
*5 The checksum size is not counted except when "CHK" is indicated.
