Output Paper
[Inserter 1] or [Inserter 2]
The gray sheets: Paper placed in the inserter
Nothing will be printed on the paper used for the cover.
You cannot use this function in combination with 'Transparency Interleaving'.
This function cannot be used if the 'Finishing' is set to [Off], [Collate], [Offset+Group], or [Staple+Group].
This function is available for selection if the Document Insertion Unit-K1 is attached.
You can place the following paper sizes and types in the Document Insertion Unit-K1 :
Paper sizes: 13" x 19" , 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, LTR, LTRR, EXEC, A3, B4, A4, A4R, B5, B5R, and Custom Size (7 1/8" x 7 1/8" to 13” x 19 1/4" (182 mm x 182 mm to 330.2 mm x 487.7 mm))
Paper types: Thin, Plain, Recycled, Color, Heavy, Letterhead, Bond, Tab, Pre-Punched, Tracing, Coated
