Category Top
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Paper Output
Print Quality
Layout
Auto Continue
Secure Print Delete Time
Timeout
Print After Completing RIP
Booklet
Saddle Stitch
Creep Correction
Use Cover Inserter
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Initialize
UFR II Settings
Halftones
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
PS Settings
Job Timeout
Print PS Errors
Halftones
Grayscale Conversion
Dot Gain Adjustment
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Halftones
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Halftones
Dot Gain Adjustment
XPS Settings
Halftones
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » Settings Menu (Common Settings) » Print Quality
Print Quality
08KE-1EW
Image Refinement
[On]*, [Off]
This setting smoothes the jagged outlines of characters and graphics.
If [On] is selected, smoothing is performed before printing.
If [Off] is selected, jobs are printed without being smoothed.
The function is not available if 'Resolution' is set to [1200 dpi].
The results of image refinement may be different depending on the types of characters and graphics you want to print.
Density
-8 to +8; 0*
This mode is not available if you set [Toner Save] to [On].
This setting adjusts the print density.
Pressing [Dark] makes the print image darker, pressing [Light] makes the image lighter. This setting has 17 levels you can adjust, with level 0 (middle level) being the default setting.
Density (Fine Adjust)
[High]
-8 to +8; 0*
[Medium]
-8 to +8; 0*
[Low]
-8 to +8; 0*
Toner Save
[On], [Off]*
This setting enables you to set the Toner Save mode. Toner Save uses less toner to print documents and may result in longer toner life.
Line Refinement
[On]*, [Off]
This setting enables clearer printing of fine lines and small characters, or when you want to print
characters and lines thicker.
This setting is applicable only when 'Resolution' is set to [1200 dpi].
This setting remains in effect even when the printer job is sent to a box.
Horizontal Line Refinement
[Off]*, [Level 1], [Level 2], [Level 3], and [Level 4]
This setting adjusts the thickness of horizontal lines to express fine lines and small characters more clearly. The higher the level number, the thicker the horizontal lines printed.
This setting is also available when 'Line Refinement' is set to [On] in the printer driver.
With this setting, horizontal lines are based on the direction in which the paper is fed.
Selecting [Level 2] or higher for this setting may result in abrupt changes in gradation with halftone images.
Vertical Line Refinement
This setting adjusts the thickness of vertical lines to express fine lines and small characters more clearly.
The higher the level number, the thicker the vertical lines printed.
With this setting, vertical lines are based on the direction in which the paper is fed.
Resolution
[1200 dpi], [600 dpi]*
This setting specifies the resolution for printing.
Resolution is expressed in units of dpi (dots per inch), indicating the number of dots in one inch. The higher the value, the greater the resolution, allowing finer expression of detail.
[1200 dpi]
The outline of characters and diagrams can be finely printed. This is suited to printing data containing fine lines and small characters.
[600 dpi]
You can perform printing suited to general documents and tables.
If you select [1200 dpi] for [Resolution], you cannot specify the following settings: rotate collate, different paper sizes (LTR/LGL), and double stapling on the short edge of A4 and LTR size paper.
