Category Top
Personality
Menu Functions
Accessing the Settings Menu
Canceling Print Jobs
Report Settings
Copies
2-Sided Printing
Paper Feed
Paper Output
Print Quality
Layout
Auto Continue
Secure Print Delete Time
Timeout
Print After Completing RIP
Booklet
Saddle Stitch
Creep Correction
Use Cover Inserter
Transparency Interleaving
Copy Set Numbering
Personality
Mode Priority
Initialize
UFR II Settings
Halftones
Paper Save
PCL Settings
Paper Save
Orientation
Font Number
Point Size
Pitch
Form Lines
Character Code
Custom Paper
Unit of Measure
X Dimension
Y Dimension
Append CR to LF
Enlarge A4 Print Width
Halftones
PS Settings
Job Timeout
Print PS Errors
Halftones
Grayscale Conversion
Dot Gain Adjustment
Imaging Settings
Image Orientation
Zoom Mode
Print Position
Show Warnings
Enlarge Print Area
Halftones
PDF Settings
Enlarge/Reduce to Fit Size
Enlarge Print Area
N on 1
Comment Print
Halftones
Dot Gain Adjustment
XPS Settings
Halftones
Utility Settings
Restricting Printer Jobs
PDL Selection (Plug-n-play)
Printing Problems
Some Basic Facts about Fonts
What Is a Font?
Attributes of Fonts
Fonts and Scalable Fonts
Typeface Samples
Symbol Sets 1
Symbol Sets 2
Symbol Sets 3
Symbol Sets 4
Symbol Sets 5
Configuration Page
Release Notes
Bar Code Printing
Introduction
Menus and Their Functions
Building/Printing a Bar Code
Control Codes
Font Parameters
Bar Code Format Parameters
Bar Code Usages and Formats
Troubleshooting
List of Error Messages
Printing Problems
Printing Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
Common Functions
[Device Settings] Tab
System Requirements
Installation
Setting the Printer Options
Other Software Programs
Printing Fundamentals
Printing
Viewing the Online Help
Scaling Documents
1-sided and 2-sided Printing
Booklet Printing
Poster Printing
Watermark Printing
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
System Requirements
Installation
Printing
Scaling Documents
Setting Custom Paper Sizes
Booklet Printing
Using [Presets] for Printing
Top » Print » Setting the Machine (PS/PCL/UFR II Printer) » If Trouble Occurs When Downloading Fonts or Macros from a Personal Computer
08KE-1JE
If trouble occurs when fonts or macros are downloaded from a personal computer to this machine and the problem cannot be resolved by reinstalling, follow the steps explained in this section to initialize the hard disk partition.
Only Administrator can initialize the hard disk. Contact the Administrator to execute this procedure.
The font or macros information downloaded to the hard disk is deleted by initializing the hard disk.
Do not turn OFF the power when the hard disk is initializing. Doing so may damage the machine.
The hard disk cannot be initialized in the following conditions:
When print data is being received or printed. (It is recommended that you remove the cable connecting the machine to the hub, so it does not receive print data.)
When fonts are being installed or uninstalled.
The steps explained below are for initializing the PCL Hard Disk partition.
To initialize the PS Hard Disk partition, follow the same steps, except that for step 4, select [Initialize PS Hard Disk].
Press [Function Settings] → [Printer] → [Printer Settings].
To move up one level, press [Up].
Press [Utility].
4.
Press [Initialize PCL Hard Disk].
A confirmation message appears.
5.
Press [Yes].
If you do not wish to initialize the hard disk, press [No].
During initialization, the Processing/Data indicator blinks green.
When the initialization of the hard disk is completed, the Processing/Data indicator goes out.
The duration of the hard disk initialization process depends on the number of fonts and macros on the hard disk.
Do not turn OFF the power until the Processing/Data indicator goes out. Doing so may damage the machine.
If the following screen appears after pressing [Yes], the hard disk has not been initialized. Check whether print data is received and retry.
