Category Top
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Setting the Control Panel Display
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting the Receiving Machine
Setting Automatic Delivery
Setting Manual Delivery
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
ACCESS MANAGEMENT SYSTEM
Starting the Setup Guide
Retrieving Audit Logs
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Key Pair and Server Certificate Settings for Encrypted SSL Communication » Generating a Key Pair and Server Certificate
0C1Y-1R8
It is necessary to generate and register a key pair in order to use encrypted SSL communication for IPP printing, e-mail and I-faxes, the Remote UI, MEAP functions via a Web browser, device information delivery, and confirming Department IDs and PIN, or when using the MEAP SMS.
A key pair and server certificate are preinstalled in the machine. You can also perform encrypted SSL communication using the preinstalled key pair and server certificate.
The procedure for generating and registering a key pair and self-signed server certificate using the control panel of the machine is as follows:
Press [Management Settings] → [Device Management] → [Certificate Settings].
Press [Generate Key].
4.
Press [Generate Network Communication Key] → specify the following settings → press [Next].
If device signature is disabled, it is not necessary to press [Generate Network Communication Key]. If you press [Generate Key], the screen changes to the screen for generating a network communication key.
Items you can set:
[Key Name]: Enter a name for the key pair.
<Signature Algorithm>: Select the hash function to use for the signature. Keys that are 1024-bit or longer support the hash function of SHA384 and SHA512. To set [SHA384] or [SHA512], select [1024], [2048], or [4096] in <Key Type>.
<Key Algorithm>: Select [RSA] (Rivest Shamir Adleman) or [ECDSA] (Elliptic Curve Digital Signature Algorithm).
<Generate Key: Key Length (bit) Settings>: If you select [RSA] in <Key Algorithm>, select [512], [1024], [2048], or [4096].
<Generate Key: Key Length (bit) Settings>: If you select [ECDSA] in <Key Algorithm>, select [P256], [P384], or [P521].
The name of the preinstalled key pair is 'Default Key'.
You cannot specify 'Device Signature Key' (used for key pairs for adding digital signatures to PDF or XPS files) or 'AMS' (used for key pairs for access restrictions) as the name for the key pair.
5.
Set the self-signed server certificate → press [Next] → specify each setting.
You cannot set an end date which is earlier than the start date.
Set at least one of the following items. You cannot issue a server certificate if all the items are left blank. When using IPPS printing with Windows Vista/7/8/Server 2008/Server 2008 R2/Server 2012, make sure to enter the IP address of the machine in [Common Name].
Items you can set:
[Country/Region]:
Select the country/region name from the 25 countries/regions in the list, or enter an Internet country code.
[State]:
Set the state name.
[City]:
Set the city name.
[Organization]:
Set the organization name.
[Organization Unit]:
Set the organization unit, such as the department name.
[Common Name]:
Set the IP address or FQDN (for example, starfish.company.com) of the machine.
A DNS server is necessary to use the FQDN of the machine in [Common Name]. Use the IP address of the machine if you do not have a DNS server.
The key pair you have registered cannot be used for encrypting communications with SSL until it has been set as the default key. For instructions on setting the default key, see "Setting the Key Pair Used With SSL Encrypted Communications."
6.
Press [Generate Key] → [OK].
Up to six key pairs can be registered.
To confirm the key pair and server certificate you have registered, see "Editing Key Pairs and Server Certificates."
After pressing [Generate Key], you cannot use any of the keys until a key pair has been generated and registered.
