Restricting Access by Authentication
0C1Y-1L8
The authentication on this machine requests user information (user name and password) when users access the machine, and verifies that information. Only an authorized user that has successfully passed the authentication can operate the machine. You can prevent access by unauthorized users by managing the users for the machine. To use the authentication mode, you must first register the information for administrators and general users.
The administrator can restrict various functions such as Copy, Print, and Send that each user can use and limit the maximum number of copies/prints that each user can output. Also, if necessary, the administrator can restrict settings on "Settings/Registration."
Authentication Information (Administrator/General User/Unauthorized User)
The administrator manages the users by restricting access by general user and setting restrictions on operations using the authentication mode. General user privileges can be set per users. By preventing access by unauthorized users, administrators can reduce the threat of tampering of the machine and information leakage.
You can use the following authentication functions:
Department ID Management (Default Authentication)
You can manage the users by department or project by registering the Department ID and PIN. The Department ID Management enables you to restrict various functions such as Copy, Print, and Send that each department can use, and the Page Limits for Copy, Scan, and Print for each department.
(See "Department ID Management.")
SSO-H (Single Sign-On H)
The SSO-H enables you to perform user authentication by registering user names and passwords.
There are two types of authentication method: Server Authentication, which performs authentication using the outside server connected to the machine, and Local Device Authentication, which performs authentication using only the machine. You can use both authentication methods at the same time.
(See "SSO-H (Single Sign-On H).")
Also, you can limit use of particular device functions for each user using the ACCESS MANAGEMENT SYSTEM. For example, you can restrict Copy/Print functions, such as 2-sided printing, or the use of various settings in Settings/Registration.
User Setting Information Management (User Setting Information Management Service)
This mode enables you to link information such as the user name and password set for each function by each user with the SSO-H user information.
You can delete the user setting information that each user is using from the User Setting Information Management Service page.
(See "User Setting Information Management (User Setting Information Management Service).")
Authentication Method Settings for Sending Operations
You can specify what type of authentication method you use for accessing personal folders or external servers, and which user name and password you use as authentication information.
(See "Authentication Method Settings for Sending Operations.")
Secure Printing Simple Authentication Settings
When you are performing user management using a login service such as SSO-H, you can perform secure printing without having to enter a user name and password each time.
(See "Simple Authentication Settings for Secure Print.")
Integrated Authentication
This function enables you to use the login information, required to log in to the machine, for other authentications. If the login service you are using supports integrated authentication, it is not necessary for logged in users to perform authentication by entering a login name and password when using functions that are allowed (such as sending to personal folders or accessing LDAP servers and file servers).
For information whether the login service you are using supports Integrated Authentication, contact your local authorized Canon dealer.
