Category Top
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Setting the Control Panel Display
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting the Receiving Machine
Setting Automatic Delivery
Setting Manual Delivery
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
ACCESS MANAGEMENT SYSTEM
Starting the Setup Guide
Retrieving Audit Logs
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Device Management » Remote UI
Remote UI
0C1Y-1SX
This mode enables you to use the Remote UI (User Interface) to operate the machine and change settings.
Press [Management Settings] → [License/Other] → [Remote UI].
Press [On] → specify each setting → press [OK].
Press [Off] to disable setting the machine from the Remote UI.
Press [On] for <Use SSL> to use SSL communication.
Before setting <Use SSL> to 'On', it is necessary to set a default key in [Preferences] (Settings/Registration). (See "Setting the Key Pair Used With SSL Encrypted Communications.")
Any changes made to <Use SSL> are also applied to [Use SSL] in [MEAP Settings] in [Management Settings] (Settings/Registration). (See "MEAP Settings.")
For more information on the Remote UI, see "Remote UI."
Changes are only effective after you restart the machine (the main power switch is turned Off, and then back On). For instruction on restarting (turning the main power switch Off and then On) the machine, see "Main Power and Energy Saver Key."
