When the Setup Guide is started and closed, the machine will restart. Before the machine is restarted, make sure that there are no jobs currently in progress.
(Settings/Registration).|
Procedure
Item
Setting Description
Remarks
Required Permission Level
1
<Language/Keyboard Switch>
Select the displayed language and keyboard layout.
General Users/System Managers
2
<Toner Mixing>
Press [Start] to start mixing toner.
3
<Paper Settings>
Set the paper size for each paper drawer.
You can close the Setup Guide here. To close the Setup Guide, press [End].
4
<Date/Time Settings>
Set the date and time.
The Log In screen is displayed. Log in as an administrator.
System Manager
5
<Use IP Address>
Specify IPv4 and/or IPv6, and each IP address.
6
<DNS Server Address Settings>
Configure the DNS Server Address Settings, the DNS Host/Domain Name Settings, and the DNS Dynamic Update Settings.
7
<Proxy Settings>
Specify the Proxy Settings.
8
<Country/Region>
Set the country/region.
9
<Register Unit Telephone Number>
Enter the phone number for the machine.
10
<Register Unit Name>
Enter the name the machine will appear as on the network.
11
<Select Line Type>
Select line Type
12
<System Manager Information Settings>
Configure the System Manager Settings.
For more information on the operation, see "Using the Setup Guide to Configure the Machine."
