Accepting Jobs with Unknown Department IDs
0C1Y-1LH
You can specify to accept print jobs from printer drivers that do not correspond with a registered Department ID, and network scan jobs from computers that do not correspond with a registered Department ID.
The <Allow Printer Jobs with Unknown IDs> and <Allow Remote Scan Jobs with Unknown IDs> settings are only enabled when the machine is equipped with the Print function and Remote Scan function.
Press
(Settings/Registration).
Press [Management Settings] → [User Management] → [Department ID Management].
Accepting Print and Scan Jobs with Unknown IDs
When the Copy Card Reader-F1 is not attached:
Press [On].
Press [On] → [OK].
When the Copy Card Reader-F1 is attached:
Press [On] → [OK].
Set <Allow Printer Jobs with Unknown IDs> to 'Off' to reject print jobs from printer drivers that do not support Department ID Management.
Set <Allow Remote Scan Jobs with Unknown IDs> to 'Off' to reject scan jobs from computers that do not support Department ID Management.
