Registering Personal Folders for Each User
This function enables each user to register a folder as the personal folder.
This method is suitable for the case that each user wants to send files to the preferred folder, or to the destination which other user cannot view easily.
Administrator Settings
In this procedure, select [Register for Each User] to specify the personal folder.
Press [Function Settings] → [Send] → [Common Settings].
Press [Personal Folder Specification Method] → [Register for Each User] → [OK].
General User Settings
The procedure below describes how to register the folder path for the personal folder and authentication information for each user.
Log in to the machine.
Press [Main Menu] → [Scan and Send] → .
Press [Register/Edit Info. for Each User].
You can register user information from  on the [Scan and Send] Basic Features screen and the [Fax/I-Fax Inbox] Send screen.
4.
Press [Personal Folder].
5.
Specify each setting.
The available protocols are SMB, FTP, and WebDAV.
For more information on each setting item, see "Specifying a File Server Using the Keyboard."
6.
Press [OK].
The personal folder for the login user is set.
» Security » Authentication Method Settings for Sending Operations » Specifying Personal Folders » Registering Personal Folders for Each User
0C1Y-1LW
