Category Top
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Authentication Method Settings for Sending Operations
Specifying Personal Folders
Registering Personal Folders for Each User
Setting Up the Home Folder and Personal Folders
Registering Folders Designated by Login Service as Personal Folders
Specifying Authentication Method for LDAP Server
Specifying Authentication Method for Rights Management Server
Specifying Authentication Method for SMTP Server
Specifying Authentication Method for File Server
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Setting the Control Panel Display
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting the Receiving Machine
Setting Automatic Delivery
Setting Manual Delivery
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
ACCESS MANAGEMENT SYSTEM
Starting the Setup Guide
Retrieving Audit Logs
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Device Management » Limiting Functions
Limiting Functions
0C1Y-1SW
If a problem frequently occurs when using the Finishing modes, such as Offset Collate and Staple, you can temporarily limit the use of these finishing modes by setting Limited Functions Mode to 'On'.
In addition, when the Service Call Message screen appears indicating a finishing mode malfunction and you temporally set the Limited Functions Mode to clear the Service Call Message screen, you can deactivate the Limited Functions Mode by setting this mode to 'Off' from the Settings/Registration screen. However, after the Limited Functions Mode is deactivated, the Service Call Message screen may appear again, unless the cause of the malfunction is cleared. (See "Service Call Message.")
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Press [Management Settings] → [Device Management] → [Limited Functions Mode].
Press [On] → [OK].
Press [Off] to not use the limited functions mode.
Changes are only effective after you restart the machine (the main power switch is turned Off, and then back On). For instruction on restarting (turning the main power switch Off and then On) the machine, see "Main Power and Energy Saver Key."
