      0SU0-04U
      System Management Settings
      All the settings about System Management Settings are listed with short descriptions. Default settings are marked with a dagger ().
      Asterisks (*)
      Settings marked with "*1" cannot be exported or imported.
      Settings marked with "*2" have different defaults depending on the country or region of purchase.
      Network Settings
      System Manager Information Settings
      Specify the ID or PIN exclusively for Administrators who have access privileges to <Network Settings> and <System Management Settings>. ID is <System Manager ID> and PIN is <System Manager PIN>. You can also register the name of an Administrator. Setting the System Manager ID
      System Manager ID and PIN
      Enter a number of up to seven digits for the System Manager ID and PIN.
      System Manager ID
      System Manager PIN
      System Manager Name
      Enter up to 32 alphanumeric characters for the name of an Administrator.
      Device Information Settings
      Enter up to 32 alphanumeric characters for the name and the installation location to identify the machine.
      Device Name
      Location
      Department ID Management On/Off
      Select whether to use the Department ID Management, a feature that uses IDs as user accounts to specify access privileges and maintain information on how the machine is used. Setting the Department ID Management
      Off
      On
      Security Settings
      Enable or disable settings for encrypted communication via SSL or IPSec, as well as settings for IP address or MAC address packet filtering.
      Use SSL *1
      Select whether to use SSL encrypted communication. Enabling SSL Encrypted Communication for the Remote UI
      Off
      On
      Use IPSec
      Select whether to perform encrypted communication by establishing a virtual private network (VPN) via IPSec. Configuring IPSec Settings
      Off
      On
      IPv4 Address Filter
      Enable or disable settings for filtering packets sent to or received from devices with specified IPv4 addresses. Specifying IP Addresses for Firewall Rules
      Outbound Filter
      Off
      On
      Inbound Filter
      Off
      On
      IPv6 Address Filter
      Enable or disable settings for filtering packets sent to or received from devices with specified IPv6 addresses. Specifying IP Addresses for Firewall Rules
      Outbound Filter
      Off
      On
      Inbound Filter
      Off
      On
      MAC Address Filter
      Enable or disable settings for filtering packets sent to or received from devices with specified MAC addresses. Specifying MAC Addresses for Firewall Rules
      Outbound Filter
      Off
      On
      Inbound Filter
      Off
      On
      Select Country/Region *1*2
      Specify the country or region where the machine is used. The default setting may vary depending on the setting selected at initial power-on.
      United States (US)
      Canada (CA)
      Brazil (BR)
      Mexico (MX)
      Other
      Remote UI Settings *1
      Select whether to use the Remote UI, a feature that enables you to specify the machine settings by using a Web browser. Disabling Remote UI
      Use Remote UI
      Off
      On
      Display Job Log
      Select whether to display the printing logs on the display of the machine.
      Off
      On
      Use as USB Device
      Enable or disable the USB port that is used for connecting the machine to a computer. Restricting the USB Connection with a Computer
      Off
      On
      Memory Media Print On/Off
      Select whether to permit printing data from a USB memory device when it is attached to the machine. Restricting the USB Print Function
      Off
      On
      Import/Export of Settings *1
      You can export the menu options data from the machine to a USB memory device, or import it to the machine from a USB memory device. Using a USB Memory Device to Export/Import Registered Data
      Secure Print Settings
      Enable or disable Secure Print. Printing via Secure Print
      Off
      On
      Secure Print Del. Time
      10 to 30 to 240 (min.)
      PDL Selection (Plug and Play)
      Select a page description language so that the machine is detected as a printer that is compatible with that language when it is connected to a computer by using Plug and Play.
      Network
      Select a page description language so that the machine is detected as a printer that is compatible with that language when it is detected over the network.
      UFR II LT
      UFR II LT (XPS)
      PCL5
      PCL6
      PS
      USB
      Select a page description language so that the machine is detected as a printer that is compatible with that language when it is connected to a computer via USB.
      UFR II LT
      UFR II LT (XPS)
      PCL5
      PCL6
      PS
      Register License *1
      Register the license key to activate the functions that require the license. License Registration
      Update Firmware *1
      Select how to install the firmware update according to the environment of the machine.
      <Via PC>
      Select to manually install the firmware update available on the Canon website yourself. For instructions on how to install the update, see the instruction manual available on the website.
      <Via Internet>
      Select to automatically install the firmware update without using a computer. Follow the on-screen instructions to perform the update. The machine must be connected to the Internet.
      Via PC
      Via Internet
      Initialize Key and Certificate *1
      Select to restore [Key and Certificate Settings] and [CA Certificate Settings] to the factory defaults. Initializing Key and Certificate
      Initialize Menu *1
      Select to restore the settings listed below to the factory defaults. You can restore all the settings listed below at once, or you can restore individual settings separately. Initializing Menu   Initializing System Management Settings
      Preferences
      Timer Settings
      Common Settings
      Memory Media Print Settings
      Printer Settings
      Network Settings
      Security Settings
      Use Remote UI
      Display Job Log
      Use as USB Device
      Initialize All
      Initialize All
