      0SU0-04J
      Timer Settings
      All the settings about the timer are listed with short descriptions. Default settings are marked with a dagger ().
      Asterisks (*)
      Settings marked with an asterisk (*) cannot be exported or imported.
      Date/Time Settings
      Specify date and time settings, including the date format and the 12- or 24-hour clock display setting. The date and time that are printed on each report and list are determined by these settings.
      Date Format
      Select the date format (order of year, month, and day).
      YYYY MM/DD
      MM/DD/YYYY
      DD/MM YYYY
      Time Format
      Select the 12- or 24-hour clock display setting.
      12 Hour (AM/PM)
      24 Hour
      Current Date/Time Settings*
      Set the current date and time. Use / to move the cursor, and use the numeric keys or / to specify the date and time or switch between <AM>/<PM>.
      Set <Time Zone> before setting the current date and time. If the <Time Zone> setting is changed, the current date and time are also changed accordingly.
      The current date and time cannot be changed for 1 hour after daylight saving time is in effect.
      Time Zone
      Select the time zone. If the time zone setting is changed, the values set in <Current Date/Time Settings> are also changed accordingly.
      UTC-12:00 to UTC-5:00 to UTC+12:00
      UTC
      Coordinated Universal Time (UTC) is the primary time standard by which the world regulates clocks and time. The correct UTC time zone setting is required for Internet communications.
      Daylight Saving Time Settings
      Enable or disable daylight saving time. If you enable it, specify the dates from which and to which daylight saving time is in effect.
      Off
      On
      Start: Month, Week, Day
      End: Month, Week, Day
      Auto Reset Time
      If a key is not pressed for a specified period of time, the screen and the settings are initialized to display the main screen (Auto Reset). Specify the period of time after which Auto Reset is performed. Select <0> to disable the Auto Reset function. Auto Reset is not performed in such cases as follows:
      The setting menu screen is displayed.
      The machine is processing a job, such as when printing data in a USB memory device.
      An error message is displayed and the error indicator is blinking (Auto Reset is performed when the error does not prevent user's operation.)
      0 (Auto Reset is disabled.)
      1 to 2 to 9 (min.)
      Auto Sleep Time
      If the machine has not been operated or has had no data to process for a specified period of time, the machine enters sleep mode to save energy consumption (Auto Sleep). Specify the period of time after which auto sleep is performed. Auto Sleep is not performed when the setting menu is displayed. It is recommended to use the factory-installed settings for this item. Entering Sleep Mode
      3 to 5 to 240 (min.)
