      0SU0-06A
      Initializing Menu
      You can restore the current settings registered in the machine to the factory defaults (Setting Menu List).
      For instructions on how to restore the settings for <Network Settings> and <System Management Settings>, see Initializing System Management Settings.
      1
      Press .
      2
      Use / to select <System Management Settings>, and press .
      If the logon screen appears, enter the correct ID and PIN using the numeric keys, and then press . Logging on to the Machine
      3
      Select <Initialize Menu>, and press .
      4
      Select the item that you want to initialize, and press .
       Items for initializing
      Select the setting that you want to initialize.
       <Initialize All>
      Initializes all the settings.
      5
      Select <Yes>, and press .
      6
      Restart the machine if necessary.
      Turn OFF the machine, wait for at least 10 seconds, and turn it back ON.
