All the settings about adjustment and maintenance are listed with short descriptions. Default settings are marked with a dagger (
Nine Levels
Off
![]() On
When this setting is enabled, fine lines and portions with lighter print density may become blurred.
This setting does not affect toner consumption when printing with the printer driver. For instructions on how to conserve the amount of toner when printing with the printer driver, see Printing with Toner Save Setting.
Off
![]() On
If both <Special Mode P> and <Special Mode N> are enabled, <Special Mode P> overrides <Special Mode N>.
<Adjustment/Maintenance>
<Special Processing>
<Special Mode P>
<On>
Off
Mode 1 ![]() Mode 2 Mode 3 |
<Special Mode X>
Select the mode
Mode 1
Mode 2 Mode 3
![]() Mode 4
Mode 5
<Special Mode M>
Select the mode
Auto
![]() Off
Mode 1 Mode 2 |
Do not use paper that has been exposed to high temperature or humidity for an extended period of time. Printing on such paper may result in frequent paper jams.
If both <Special Mode P> and <Special Mode N> are enabled when printing on a lightweight paper, <Special Mode P> overrides <Special Mode N>.
<Special Mode N>
Select the mode
Off
![]() On |
<Special Mode O>
<On>
Off
![]() On |
If this mode is enabled, the previously printed image may re-appear faintly on the next output.
<Special Mode S>
<On>
Off
![]() Mode 1
Mode 2 |
When this setting is activated, it may take the machine longer to print the first page.
When <Mode 2> is selected, it takes the machine longer to print than when <Mode 1> is selected.
<Special Mode Y>
Select the mode
