      0SU0-06E
      Initializing System Management Settings
      You can restore the current <System Management Settings> registered in the machine to the factory defaults (Setting Menu List). For some settings, you need to restart the machine to complete the initialization.
      1
      Press .
      2
      Use / to select <System Management Settings>, and press .
      If the logon screen appears, enter the correct ID and PIN using the numeric keys, and then press . Logging on to the Machine
      3
      Select <Initialize Menu> <System Management Settings>.
      4
      Select the item that you want to initialize, and press .
       Items for initializing
      Select the setting that you want to initialize.
       <Initialize All>
      Initializes all the settings.
      5
      Select <Yes>, and press .
      6
      Restart the machine if necessary.
      Turn OFF the machine, wait for at least 10 seconds, and turn it back ON.
      To initialize the settings in <Network Settings>, you can also press   <Network Settings>    <Initialize Network Settings>    <Yes>    restart the machine.
