      0SU0-04H
      Preferences
      All the settings about the sound, display, and USB keyboard are listed with short descriptions. Default settings are marked with a dagger ().
      Sound Volume Control
      Specify the sound settings such as whether the machine beeps when a key is pressed or when a paper jam occurs. Specifying the Sound Settings
      Entry Tone
      Select whether the machine beeps when a key is pressed on the operation panel.
      Off
      On
      Invalid Entry Tone
      Select whether the machine beeps when an invalid setting value is entered, such as when a user is trying to enter a number unavailable for a setting.
      Off
      On
      Restock Supplies Tone
      Select whether the machine beeps when the toner cartridge is almost empty.
      Off
      On
      Warning Tone
      Select whether the machine beeps when problem such as a paper jam or an operation mistake occurs.
      Off
      On
      Job Done Tone
      Select whether the machine beeps when printing is complete.
      Off
      On
      Energy Saver Alert
      Select whether the machine beeps when the machine enters or wakes from sleep mode.
      Off
      On
      Display Settings
      Brightness
      Adjust the brightness of the display to suit the installation location of the machine.
      Five Levels
      Contrast
      Adjust the contrast between the black and white on the display to enhance the visibility.
      Seven Levels
      Invert Screen Colors
      Select <On> to invert the display colors (black and white). Select <On> if the display is hard to view even after the brightness and contrast were adjusted in <Brightness> and <Contrast>.
      Off
      On
      Millimeter/Inch Entry Switch
      Select the unit of measurement.
      Millimeter
      Inch
      Gram/Pound Switch
      Select the unit of measurement for the basis weight.
      Gram
      Pound
      Message Display Time
      Specify the interval in seconds at which two different messages are alternately displayed.
      1 to 2 to 5 (sec.)
      Scrolling Speed
      Adjust the speed for scrolling the screen by selecting from three levels.
      Slow
      Standard
      Fast
      Cursor Movement
      Configure how the cursor moves after a character is entered on the screen. Select <Auto> to automatically move the cursor to the right of the entered character after approximately 1 second. Select <Manual> to manually move the cursor to the right of the entered character.
      Auto
      Manual
      Language
      Select the display language used for the display, reports, and lists.
      English
      French
      Spanish
      Portuguese
      Remote UI Language
      Select the display language used for the Remote UI screens.
      English
      French
      Spanish
      Portuguese
      English Keyboard Layout
      Select the key layout type for the USB keyboard connected to the machine. Specify this setting if you are using a keyboard with the key layout for entering English text. Also, to make this setting effective, select <English> in the <Language> setting (Language).
      USA Layout
      UK Layout
      Using a non-English type USB keyboard
      If you select <French> or <Spanish> as the display language in the <Language> setting (Language), the connected keyboard operates as a keyboard for the selected language. If you select <French>, for example, you can use the keyboard to enter French text.
      If <Portuguese> is selected, the keyboard operates as an English keyboard regardless of the actual type.
      keyboards incompatible with the machine, or keyboard types for the languages that you cannot select in the <Language> setting may not work properly.
