      0SU0-04E
      Network Settings
      All the settings about the network are listed with short descriptions. Default settings are marked with a dagger ().
      Asterisks (*)
      Settings marked with an asterisk (*) cannot be exported or imported.
      TCP/IP Settings
      Specify settings for using the machine in a TCP/IP network, such as IP address settings.
      IPv4 Settings
      Specify settings for using the machine in an IPv4 network.
      IP Address Settings
      Configure the IP address, which is used for identifying devices, such as computers and printers, on a TCP/IP network. Setting IPv4 Address
      Auto Acquire
      Select Protocol
      Off
      DHCP
      Auto IP
      Off
      On
      Manually Acquire
      IP Address: 0.0.0.0
      Subnet Mask: 0.0.0.0
      Gateway Address: 0.0.0.0
      Check Settings
      Auto Acquire
      IP Address
      Subnet Mask
      Gateway Address
      PING Command*
      Select to check that the machine is connected to a computer over a network. Testing the Network Connection
      DNS Settings
      Specify settings for Domain Name System (DNS), which provides a host name for IP address resolutions. Configuring DNS
      DNS Server Settings
      Primary DNS Server: 0.0.0.0
      Secondary DNS Server: 0.0.0.0
      DNS Host Name/Domain Name Settings
      Host Name
      Domain Name
      DNS Dynamic Update Settings
      Off
      On
      DNS Dynamic Update Interval
      0 to 24 to 48 (hr.)
      mDNS Settings
      Specify settings for using DNS functions without DNS servers. Configuring DNS
      Off
      On
      mDNS Name
      DHCP Option Settings
      Select whether to acquire the host name and whether to use the dynamic update function via the DHCP options when DHCP is enabled. Configuring DNS
      Acquire Host Name
      Off
      On
      DNS Dynamic Update
      Off
      On
      IPv6 Settings
      Specify settings for using the machine in an IPv6 network.
      Use IPv6
      Enable or disable IPv6 in the machine. You can also view the current settings. Setting IPv6 Addresses
      Off
      On
      Check Settings
      Stateless Address Settings
      Enable or disable stateless addresses. Setting IPv6 Addresses
      Off
      On
      Check Settings
      Use DHCPv6
      Enable or disable the stateful address that is acquired via DHCPv6. Setting IPv6 Addresses
      Off
      On
      Check Settings
      DNS Settings
      Use IPv4 Host/Domain
      Off
      Host Name
      Domain Name
      On
      Off
      On
      Register Manual Address
      Off
      On
      Register Stateful Address
      Off
      On
      Register Stateless Address
      Off
      On
      0 to 24 to 48 (hr.)
      mDNS Settings
      Off
      On
      Use IPv4 Name for mDNS
      Off
      mDNS Name
      On
      WINS Settings
      Specify settings for Windows Internet Name Service (WINS), which provides a NetBIOS name for IP address resolutions in a mixed network environment of NetBIOS and TCP/IP. Configuring WINS
      WINS Resolution
      Off
      On
      WINS Server Address: 0.0.0.0
      Scope ID
      LPD Settings
      Enable or disable LPD, a printing protocol that can be used on any hardware platform or operating system. Set the timeout minutes to disconnect to the computer. Configuring Printing Protocols and WSD Functions
      LPD Print Settings
      Off
      On
      RX Timeout
      1 to 5 to 60 (min.)
      RAW Settings
      Enable or disable RAW, a Windows specific printing protocol. Set the timeout minutes to disconnect to the computer. Configuring Printing Protocols and WSD Functions
      RAW Print Settings
      Off
      On
      RX Timeout
      1 to 5 to 60 (min.)
      WSD Settings
      Enable or disable automatic browsing and acquiring information for the printer by using the WSD protocol that is available on Windows Vista/7/8/8.1/Server 2008/Server 2012. Configuring Printing Protocols and WSD Functions
      WSD Print Settings
      Use WSD Print
      Off
      On
      Use WSD Browsing
      Off
      On
      Use Multicast Discovery
      Off
      On
      Use HTTP
      Enable or disable HTTP, which is required for communications with a computer, such as when using the Remote UI and WSD printing. Disabling HTTP Communication
      Off
      On
      Port Number Settings
      Change port numbers for protocols according to the network environment. Changing Port Numbers
      LPD
      1 to 515 to 65535
      RAW
      1 to 9100 to 65535
      WSD Multicast Discovery
      1 to 3702 to 65535
      HTTP
      1 to 80 to 65535
      Multicast Discovery
      1 to 427 to 65535
      SNMP
      1 to 161 to 65535
      MTU Size
      Select the maximum size of packets the machine sends or receives. Changing the Maximum Transmission Unit
      1300
      1400
      1500
      SNMP Settings
      Specify the settings for monitoring and controlling the machine from a computer running SNMP-compatible software. Monitoring and Controlling the Machine with SNMP
      SNMPv1 Settings
      Enable or disable SNMPv1. When enabling SNMPv1, specify a community name and access privileges to Management Information Base (MIB) objects.
      Off
      On
      SNMPv3 Settings
      Enable or disable SNMPv3. Use the Remote UI to specify detailed settings that are applied when SNMPv3 is enabled.
      Off
      On
      Acquire Printer Management Information from Host
      Enable or disable the monitoring of printer management information from a networked computer running SNMP-compatible software.
      Off
      On
      Dedicated Port Settings
      Enable or disable the dedicated port. The dedicated port is used when communicating with a device management software such as imageWARE Enterprise Management Console.
      Off
      On
      Waiting Time for Connection at Startup
      Specify a wait time for connecting to a network. Select the setting depending on the network environment. Setting a Wait Time for Connecting to a Network
      0 to 300 (sec.)
      Ethernet Driver Settings
      Select the communication mode of Ethernet (half-duplex/full-duplex) and the Ethernet type (10BASE-T/100BASE-TX/1000BASE-T). You can also view the MAC address of the machine.
      Auto Detect
      Select whether to automatically detect or manually select the communication mode and the Ethernet type. Configuring Ethernet Settings
      Off
      Communication Mode
      Half Duplex
      Full Duplex
      Ethernet Type
      10BASE-T
      100BASE-TX
      1000BASE-T
      On
      MAC Address
      Check the MAC address of the machine, which is a number unique to each communication device. Viewing the MAC Address
      IEEE 802.1X Settings *
      Enable or disable IEEE 802.1X authentication. Configuring IEEE 802.1X Authentication
      Off
      On
      Device Settings Management On/Off
      Enable or disable the function for device management by using imageWARE Enterprise Management Console Device Configuration Management Plug-In. Configuring Settings for Device Management Software
      Off
      On
      Initialize Network Settings
      Select to restore the Network Settings to the factory defaults. Initializing System Management Settings
