      0SU0-012
      Entering Text
      This section describes how to enter text and numbers.
      Switching the Type of Text
      Press  to switch the type of text that is entered. The currently selected type of text is indicated as <Entry Mode: A>. You can select from three types : <A> (upper case) , <a> (lower case), or <12> (numerics).
      NOTE:
      To switch the type of text, you can also select <Entry Mode> on the screen    select the entry mode  .
      Types of Text That Can Be Entered
      The text that can be entered using the numeric keys and  are listed below.
      Key
      A
      a
      12
      @ . - _ /
      1
      ABC
      abc
      2
      DEF
      def
      3
      GHI
      ghi
      4
      JKL
      jkl
      5
      MNO
      mno
      6
      PQRS
      pqrs
      7
      TUV
      tuv
      8
      WXYZ
      wxyz
      9
      (Not available)
      0
      (space) @ . / - _ ! ? & $ % # ( ) [ ] { } < > * + = " , ; : ' ^ ` | \ ~
      (Not available)
      Deleting Text
      One character is deleted each time  is pressed. Press and hold  to delete all of the entered text.
      Moving the Cursor (Entering a Space)
      Use  or  to move the cursor. To enter a space, move the cursor to the end of the text, and press .
      Entering Text and Numbers
      Example: "Canon-1"
      1
      Press repeatedly until <A> is selected.
      2
      Press  repeatedly until the letter "C" is selected.
      3
      Press repeatedly until <a> is selected.
      4
      Press  repeatedly until the letter "a" is selected.
      5
      Press  repeatedly until the letter "n" is selected.
      6
      Press  repeatedly until the letter "o" is selected.
      7
      8
      Press  repeatedly until the symbol "-" is selected.
      9
      Press repeatedly until <12> is selected.
      10
      Press .
      11
      Select <Apply>, and press .
      Entering Characters Using a USB Keyboard
      To enter characters, you can also use a USB keyboard by connecting it to the USB port (Exterior). A USB keyboard makes it easier to enter characters on a screen on which you can enter characters.
      You can also enter characters using the keys on the operation panel while a USB keyboard is connected.
      Some special keys other than alphanumeric keys are available. For example, the [RETURN/ENTER] key on the USB keyboard corresponds to on the operation panel.
      If you are using a USB keyboard for inputting English, you can specify the type of key layout (for US English or UK English). English Keyboard Layout
      You can specify whether the machine produces sound when a key is pressed on the <Entry Tone> and <Invalid Entry Tone> settings. Specifying the Sound Settings
      You can disconnect the USB keyboard from the machine at any time. No special operation is required to disconnect it.
      Desired characters may not be entered depending on the character codes.
      Some USB keyboards may not operate correctly.
