      0SU0-02H
      Viewing Network Settings
      The IP address is not correctly configured if it is displayed as "0.0.0.0".
      Connecting the machine to a switching hub or bridge may result in a connection failure even when the IP address is correctly configured. This problem can be solved by setting a certain interval before the machine starts communicating. Setting a Wait Time for Connecting to a Network
      You can print a list of the current network settings. System Manager Data List
      Viewing IPv4 Settings
       (Status Monitor) <Network Information>    <IPv4>    Select the setting to view
      Viewing IPv6 Settings
       (Status Monitor) <Network Information>    <IPv6>    Select the setting to view
      Viewing the MAC Address
      1
      Press .
      2
      Use / to select <Network Settings>, and press .
      If the logon screen appears, enter the correct ID and PIN using the numeric keys, and then press . Logging on to the Machine
      3
      Select <Ethernet Driver Settings>, and press .
