      0SU0-02X
      Setting a Wait Time for Connecting to a Network
      When a network is designed to enjoy redundant connectivity with multiple switching hubs or bridges, it must have a mechanism to prevent packets from looping. One effective solution is to define the role of each switch port. However, communication may still be disrupted for several tens of seconds immediately after you change the way that network devices are connected, or if you add a new device. If this type of problem occurs, set a wait time for connecting to the network.
      1
      Press .
      2
      Use / to select <Network Settings>, and press .
      If the logon screen appears, enter the correct ID and PIN using the numeric keys, and then press . Logging on to the Machine
      3
      Select <Waiting Time for Connection at Startup>, and press .
      4
      Enter the wait time in second, and press .
      Use / or the numeric keys to enter the time.
      5
      Press .
