      0SU0-02E
      Setting IPv4 Address
      The machine's IPv4 address can be either assigned automatically by a dynamic IP addressing protocol, such as DHCP, or entered manually. When connecting the machine to a LAN, make sure that the connectors of the LAN cable are firmly inserted into the ports (Connecting to a LAN). You can test the network connection if necessary.
      1
      Press .
      2
      Use / to select <Network Settings>, and press .
      If the logon screen appears, enter the correct ID and PIN using the numeric keys, and then press . Logging on to the Machine
      3
      Select <TCP/IP Settings> <IPv4 Settings> <IP Address Settings>.
      4
      Configure IP address settings.
       <Auto Acquire>
      Select to automatically assign an IP address via a protocol such as DHCP. When <Auto Acquire: On> is displayed, automatic addressing is enabled.
       <Manually Acquire>
      Select to configure the IP address settings by manually entering an IP address. In order to select this option, <Auto Acquire> must be set to <Off>.
       <Check Settings>
      Select when you want to view the current IP address settings.
      Automatically assigning an IP address
      1
      Select <Auto Acquire>  <Select Protocol>.
      2
      Select <DHCP> and press .
      NOTE:
      If you do not want to use DHCP to assign an IP address
      Select <Off>. When you select <DHCP> when the DHCP service is unavailable, the machine will search whether services are provided in the network and unnecessary communication will occur.
      3
      Check that <Auto IP> is set to <On>.
      If <Off> is selected, change the setting to <On>.
      4
      Press .
      NOTE:
      IP address assigned via DHCP overrides the address obtained via Auto IP.
      Manually entering an IP address
      1
      Check that <Auto Acquire> is set to <Off>.
      If <On> is displayed, select <Auto Acquire>  , and set both <Select Protocol> and <Auto IP> to <Off>.
      2
      Select <Manually Acquire>, and press .
      3
      Specify the IP address, subnet mask, and gateway address (or default gateway).
      Specify the settings in the following order: <IP Address>  <Subnet Mask>  <Gateway Address>.
      Enter the setting using the numeric keys, and press  on each screen.
      5
      Restart the machine.
      Turn OFF the machine, wait for at least 10 seconds, and turn it back ON.
      Checking whether the settings are correct
      Make sure that the Remote UI screen can be displayed with your computer (Starting the Remote UI). If a computer is not available, you can check the connection by using the operation panel (Testing the Network Connection).
      1
      Press .
      2
      3
      <TCP/IP Settings> <IPv4 Settings> <PING Command>.
      4
      Enter the IPv4 address of another device on the network, and press .
      If a proper connection has been established, the result is displayed as shown above.
