      0SU0-034
      Configuring Settings for Device Management Software
      You can facilitate the collection and management of various information about networked devices by implementing device management software, such as imageWARE Enterprise Management Console*, into the network. Information such as device settings, and error logs is retrieved and distributed via the server computer. If the machine is connected to such a network, the device management software searches the network for the machine by using protocols such as Service Location Protocol (SLP) to gather information from the machine. This section describes the procedures of the SLP settings and settings for communication between the machine and plug-ins for imageWARE Enterprise Management Console. These settings can be specified via Remote UI.
      * For more information about imageWARE Enterprise Management Console, contact your local authorized Canon dealer.
      To use imageWARE Enterprise Management Console plug-ins
      You need to specify the following settings.
      Enable the dedicated port setting. (Dedicated Port Settings )
      Enable SNMPv1 or SNMPv3, and select [Read/Write] for the access privileges. (Monitoring and Controlling the Machine with SNMP)
      Configuring SLP Communication with Device Management Software
      1
      Start the Remote UI and log on in System Manager Mode. Starting the Remote UI
      2
      Click [Settings/Registration].
      3
      Click [Network Settings]  [TCP/IP Settings].
      4
      Specify SLP settings.
      Specifying multicast device discovery
      Notifying a device management software of the power status of the machine
      5
      Restart the machine.
      Turn OFF the machine, wait for at least 10 seconds, and turn it back ON.
      Configuring Settings for imageWARE Enterprise Management Console Plug-ins
      You can specify the settings to enable communication between the machine and imageWARE Enterprise Management Console Device Configuration Management Plug-In which is used to manage the setting values of the machine.
      1
      2
      3
      Click [Network Settings]  [Settings for Device Settings Management].
      4
      Click [Edit...].
      5
      Select [Use Device Settings Management]  [OK].
