To change protocols' port numbers, see Changing Port Numbers.
[TCP/IP Settings].
Configuring LPD or RAW|
1
Click [Edit...] in [LPD Settings] or [RAW Settings].
2
Configure the settings as necessary.
![]() [Use LPD Printing]
Select the check box to print via LPD. When not using LPD printing, clear the check box. [Use RAW Printing]
Select the check box to print via RAW. When not using RAW printing, clear the check box. [RX Timeout]
Specify timeout period from 1 to 60 minutes. The machine deletes incomplete print data sent from a computer when the specified timeout period elapses so that the machine can receive the next print job. |
3
Click [OK].
Configuring WSD|
1
Click [Edit...] in [WSD Settings].
2
![]() [Use WSD Printing]
Select the check box to print via WSD. When not using WSD printing, clear the check box. [Use WSD Browsing]
Select the check box to obtain information about the machine from a computer via WSD. This check box is automatically selected when the [Use WSD Printing] check box is selected. [Use Multicast Discovery]
Select the check box to set the machine to reply to multicast discovery messages. If the check box is cleared, the machine stays in sleep mode even when multicast discovery messages are flowing on the network. |
3
Click [OK].
Using the operation panel
LPD, RAW, and WSD settings can also be accessed from
.Setting up WSD network devices on Windows Vista/7/8/8.1
The WSD printer can be added from the printer folder. Open the printer folder (Displaying the Printer Folder)
click [Add a device] (or [Add a printer]) and follow the on-screen instructions. For more information about how to install the printer drivers for the WSD network printer, see the Printer Driver Installation Guide included with the printer driver. |
