      0SU0-02U
      Configuring Ethernet Settings
      Ethernet is a standard for communicating data in a local area network (LAN). You can set the communication mode (half-duplex/full-duplex) and the Ethernet type (10BASE-T/100BASE-TX/1000BASE-T). In general, the machine can be used without changing the defaults (Ethernet Driver Settings), but you can change these settings to suit your network environment.
      1
      Press .
      2
      Use / to select <Network Settings>, and press .
      If the logon screen appears, enter the correct ID and PIN using the numeric keys, and then press . Logging on to the Machine
      3
      Select <Ethernet Driver Settings> <Auto Detect>.
      4
      Select whether to configure Ethernet settings automatically or manually.
      Configuring Ethernet settings automatically
      Select <On>, and press . The machine detects and automatically sets the communication mode and the Ethernet type that can be used.
      Configuring Ethernet settings manually
      1
      Select <Off>, and press .
      2
      Select the communication mode.
      Select <Communication Mode>    select <Half Duplex> or <Full Duplex>  .
       <Half Duplex>
      Alternately sends and receives communication data. Select when the machine is connected to a networking device using half duplex.
       <Full Duplex>
      Simultaneously sends and receives communication data. Use this setting for most environments.
      3
      Select the Ethernet type.
      Select <Ethernet Type>    select <10BASE-T> , <100BASE-TX> or <1000BASE-T>  .
      4
      Press .
      5
      Restart the machine.
      Turn OFF the machine, wait for at least 10 seconds, and turn it back ON.
