      0SU0-03L
      Disabling HTTP Communication
      HTTP is used for communications over the network, such as when you access the machine via the Remote UI. If you are using a USB connection or are otherwise not using HTTP, you can disable HTTP to block malicious third-party intrusions via the unused HTTP port.
      Disabling HTTP disables some of the network capabilities, such as the Remote UI or WSD printing.
      1
      Press .
      2
      Use / to select <Network Settings>, and press .
      If the logon screen appears, enter the correct ID and PIN using the numeric keys, and then press . Logging on to the Machine
      3
      Select <TCP/IP Settings>  <Use HTTP>.
      4
      Select <Off>, and press .
       <Off>
      Disables HTTP communication.
       <On>
      Enables HTTP communication.
      5
      Restart the machine.
      Turn OFF the machine, wait for at least 10 seconds, and turn it back ON.
