      0SU0-02W
      Changing the Maximum Transmission Unit
      In most Ethernet networks, the maximum size of a packet that can be sent is 1500 bytes. A packet refers to a chunk of data into which the original data is divided before being sent. The maximum transmission unit (MTU) may vary on each network. Change the settings of the machine as necessary. For more information, contact your Network Administrator.
      1
      Press .
      2
      Use / to select <Network Settings>, and press .
      If the logon screen appears, enter the correct ID and PIN using the numeric keys, and then press . Logging on to the Machine
      3
      Select <TCP/IP Settings>  <MTU Size>.
      4
      Select the MTU, and press .
      5
      Restart the machine.
      Turn OFF the machine, wait for at least 10 seconds, and turn it back ON.
