All the settings about System Management Settings are listed with short descriptions. Default settings are marked with a dagger (
Asterisks (*)
Settings marked with "*1" cannot be exported or imported.
Settings marked with "*2" are only available for the imageRUNNER 1435iF.
Settings marked with "*3" have different defaults depending on the country or region of purchase.
Settings marked with "*4" are only available for the imageRUNNER 1435iF / 1435i.
Settings marked with "*5" are only available for the imageRUNNER 1435iF, or the imageRUNNER 1435i / 1435 with the optional PCL Printer Kit enabled.
Settings marked with "*6" are only available for the imageRUNNER 1435iF, or the imageRUNNER 1435i / 1435 with the optional PS Printer Kit enabled.
System Manager ID
System Manager PIN
Device Name
Location
<System Management Settings>
<Device Information Settings>
Select <Device Name> or <Location>
Enter <Device Name> or <Location> (Entering Text)
<Apply>
Off
![]() On
<Department ID Management On/Off>
Select <Off> or <On>
Off
![]() On
<Security Settings>
<Use TLS>
Restart the machine|
Off
![]() On
<Security Settings>
<Use IPSec>
Outbound Filter
Off
![]() On
Inbound Filter
Off
![]() On
<Security Settings>
<IPv4 Address Filter>
Select <Outbound Filter> or <Inbound Filter>
Outbound Filter
Off
![]() On
Inbound Filter
Off
![]() On
<Security Settings>
<IPv6 Address Filter>
Outbound Filter
Off
![]() On
Inbound Filter
Off
![]() On
<Security Settings>
<MAC Address Filter>
Restart the machine
33600 bps
![]() 14400 bps
9600 bps
7200 bps
4800 bps
2400 bps
<Communication Management Settings>
<Fax Settings>
<TX Start Speed>
Select a communication start speed
33600 bps
![]() 14400 bps 9600 bps 7200 bps 4800 bps 2400 bps |
<Fax Settings>
<RX Start Speed>
Off
![]() On |
Off
![]() On
Memory Lock PIN
Report Print
Off
On
![]() Memory Lock Time
Off
![]() On
Memory Lock Start Time
Memory Lock End Time
United States (US)
![]() Canada (CA)
Brazil (BR)
Mexico (MX)
Other
<Select Country/Region>
Select a country or region
Off
![]() On
Off
On
![]() Only When Error Occurs
Off
Use Remote UI
Off
On
Off
On ![]() |
<Auto Online for Remote Scan>
Off
![]() On
Off
On
Off
![]() On
Off
![]() On
Off
![]() On
Off
![]() Confirm Sequential Broadcast
Reject Sequential Broadcast
Off
On
<Display Job Log>
Off
On
Off
![]() On
Off
![]() On
Off
On
Enable Google Cloud Print
Off
On
![]() Google Cloud Print Registration Status
Off
On
<Notify to Check Paper Settings>
Off
On
![]() Secure Print Del. Time
10 to 30
to 240 (min.) |
Mac OS
![]() Windows
Other
Be sure to match the machine settings to the OS of the computer. If not matched, the computer will not correctly recognize the machine.
If the OS of your computer is Mac OS X 10.10 or earlier and if you want to print from a printer driver via USB, set this item to <Other>.
<Select OS for USB Connected PC>
Select the OS
FAX*2
UFR II LT
![]() UFR II LT (XPS)
PCL5*5
PCL6*5
PS*6
FAX*2
UFR II LT
PCL5*5
PCL6*5
PS*6
<PDL Selection (Plug and Play)>
Select <Network> or <USB>
Select a page description language
Restart the machine
<FAX>
<UFR II LT>
<UFR II LT (XPS)>
<PCL5>
<PCL6>
<PS>|
Via PC
![]() Via Internet
Preferences
Timer Settings
Common Settings
Copy Settings
Fax Settings*2
Scan Settings
Memory Media Print Settings
Printer Settings
Network Settings
System Manager Information Settings
Security/Remote UI Settings
Communication Management Settings*2
Forwarding Settings*2
Store/Print When Forwarding*2
Restrict TX Function*4
Register LDAP Server*4
Auth. Settings for Send Function*4
Display Job Log
Use as USB Device
Store to USB Memory
Memory Media Print On/Off
Enable Canon Mobile Scanning
Google Cloud Print Settings*1
Secure Print Settings
Initialize All
Initialize All
