1
Click [Register New Department...].
2
Specify the required settings and click [OK].
![]() [Department ID:]
Enter a number of up to seven digits for the Department ID. [Set PIN]
To set a PIN, select the check box and enter a number of up to seven digits both in the [PIN:] and [Confirm:] text boxes. [Restrict Functions:]
Select the check box for the function that you want to disable for the Department ID. NOTE:
If the [Restrict Total Prints] check box is selected, you can specify an upper limit value that is the total number of allowable print pages. Enter the upper limit value in the field of [Number of Pages:].
If the [Scan] check box is selected, scanning documents to USB memory devices, e-mails, and file servers is disabled. You can also disable scanning documents to computers via <Computer> and <Remote Scanner>. However, you can only disable scanning documents to computers for all department IDs. (Blocking Jobs When Department ID Is Unknown).
1
Click the corresponding text link under [Department ID:] to edit.
2
Change the settings as necessary and click [OK].
click [OK].|
[Department ID Page Total]
You can check the total numbers of pages copied, printed, scanned, or faxed for each Department ID.
If you want to return the counts to zero, click the corresponding text link under [Department ID:] and click [Clear Count]
[OK]. If you want to return the counts of all Department IDs to zero, click [Clear All Counts] [OK].![]() When using control cards
When the optional Copy Card Reader-F1 is attached to the machine, 300 sequential department IDs are registered automatically.
Do not edit or delete the department IDs. The control cards that correspond to the edited or deleted department IDs will be unavailable.
[Edit...].
Using the operation panel
If you only want to enable or disable the settings, you can use
on the operation panel. Department ID Management On/Off Logging on to the machine
To perform the following procedure, log on to your computer with an administrator account.
1
Select the [Use Department ID Management] check box and click [Settings] on the right of it.
For the fax driver, also select the [Allow PIN Setting] check box to enable the PIN setting.
2
Specify the settings as necessary and click [OK].
![]() [Allow PIN Setting]
Select the check box to enable the PIN setting. [Department ID]
Enter a number of up to seven digits for the Department ID. [PIN]
Enter a number of up to seven digits for the PIN if it is set for the Department ID. [Verify]
Click to verify that the correct ID and PIN are entered. This function is not available if the machine and the computer are connected via a USB or WSD (Web Services on Devices) port. [Confirm Department ID/PIN When Printing]/[Confirm Department ID/PIN when Sending Fax]
Select the check box to display the [Confirm Department ID/PIN] pop-up screen each time you print or fax from a computer. [Authenticate Department ID/PIN at Device]
Select the check box if the machine and the computer are connected via a USB or WSD port. |
3
Click [OK].
[Edit...].
