All the settings about the network are listed with short descriptions. Default settings are marked with a dagger (
Asterisks (*)
Settings marked with "*1" cannot be exported or imported.
Settings marked with "*2" are only available for the imageRUNNER 1435iF / 1435i.
Auto Acquire
![]() Select Protocol
Off
DHCP
![]() Auto IP
Off
On
![]() Manually Acquire
IP Address: 0.0.0.0
Subnet Mask: 0.0.0.0 Gateway Address: 0.0.0.0 Check Settings
Auto Acquire
IP Address
Subnet Mask Gateway Address |
DNS Server Settings
Primary DNS Server: 0.0.0.0
Secondary DNS Server: 0.0.0.0 DNS Host Name/Domain Name Settings
Host Name
Domain Name DNS Dynamic Update Settings
Off
![]() On
DNS Dynamic Update Interval
0 to 24
to 48 (hr.) |
Off
On
![]() mDNS Name
Acquire Host Name
Off
On
![]() DNS Dynamic Update
Off
![]() On
Off
![]() On
Check Settings
Off
On
![]() Check Settings
Off
![]() On
Check Settings
Use IPv4 Host/Domain
Off
Host Name
Domain Name
On
![]() DNS Dynamic Update Settings
Off
![]() On
Register Manual Address
Off
![]() On
Register Stateful Address
Off
![]() On
Register Stateless Address
Off
![]() On
0 to 24
to 48 (hr.) |
Off
On
![]() Use IPv4 Name for mDNS
Off
mDNS Name
On
WINS Resolution
Off
![]() On
WINS Server Address: 0.0.0.0
Scope ID
LPD Print Settings
Off
On
![]() RX Timeout
1 to 5
to 60 (min.) |
RAW Print Settings
Off
On
![]() RX Timeout
1 to 5
to 60 (min.) |
WSD Print Settings
Use WSD Print
Off
On
![]() Use WSD Browsing
Off
On
![]() WSD Scan Settings
Use WSD Scan
Off
![]() On
Use Computer Scan
Off
![]() On
Use Multicast Discovery
Off
On
Off
![]() On |
Off
On
Use IPP Printing
Off
On
![]() Use TLS
Off
![]() On
Off
On
LPD
1 to 515
to 65535RAW
1 to 9100
to 65535WSD Multicast Discovery
1 to 3702
to 65535HTTP
1 to 80
to 65535Multicast Discovery
1 to 427
to 65535POP3*2
1 to 110
to 65535SMTP*2
1 to 25
to 65535FTP*2
1 to 21
to 65535SNMP
1 to 161
to 65535 |
1300
1400
1500
Off
On
<Network Settings>
<SNMP Settings>
<SNMPv1 Settings>
Select <Off> or <On>
Restart the machine
Off
![]() On
<Network Settings>
<SNMP Settings>
<SNMPv3 Settings>
Restart the machine
Off
![]() On
<Network Settings>
<SNMP Settings>
<Acquire Printer Mngt. Info. from Host>
Restart the machine|
Off
On
<Network Settings>
<Dedicated Port Settings>
0
to 300 (sec.) |
Off
Communication Mode
Half Duplex
![]() Full Duplex
Ethernet Type
10BASE-T
100BASE-TX
![]() 1000BASE-T
On
Off
![]() On
<Network Settings>
<IEEE 802.1X Settings>
Off
On ![]() |
