The Remote UI is useful because the machine settings can be specified by using a Web browser on a computer. To use the Remote UI, the machine must be connected to a computer over the network. If the machine is connected to a computer via USB, or if you do not need to use the Remote UI, you might want to disable the Remote UI to reduce the risk of having your machine controlled remotely over the network by malicious third parties.
1
Press
2
Use
to select <System Management Settings>, and press
3
Select <Remote UI Settings>
<Use Remote UI>, and press
4
Select <Off>, and press
<Off>
Disables the Remote UI.
<On>
Enables the Remote UI.
5
Restart the machine.
Turn OFF the machine, wait for at least 10 seconds, and turn it back ON.
LINKS
