![](./images/book_images/pubnumbers/USRM2-4883-03/b_key_tone18.gif)
Key
A
a
12
@ . - _ /
1
ABC
abc
2
DEF
def
3
GHI
ghi
4
JKL
jkl
5
MNO
mno
6
PQRS
pqrs
7
TUV
tuv
8
WXYZ
wxyz
9
(Not available)
0
(space) @ . / - _ ! ? & $ % # ( ) [ ] { } < > * + = " , ; : ' ^ ` | \ ~
(Not available)
You can also enter characters using the keys on the operation panel while a USB keyboard is connected.
Some special keys other than alphanumeric keys are available. For example, the [RETURN/ENTER] key on the USB keyboard corresponds to
![]() If you are using a USB keyboard for inputting English, you can specify the type of key layout (for US English or UK English). English Keyboard Layout
You can specify whether the machine produces sound when a key is pressed on the <Entry Tone> and <Invalid Entry Tone> settings. Specifying the Sound Settings
You can disconnect the USB keyboard from the machine at any time. No special operation is required to disconnect it.
Desired characters may not be entered depending on the character codes.
Some USB keyboards may not operate correctly.
